Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Will upgrade to RC8 and test instead.
  • Sorry to become a little bit OT.
    I just build up a new Copter, because of my Taranis Issue.
    I use a GPS N8M which I have to mount in its opposite direction. See Picture!
    COMPASS_ORIENT=12 (pitch180) and did my Compass calibration with MissionPlaner.
    Sometimes the Compass show North (the Copter front looks to North) some times East or West. Of course I can´t Arm the copter. I disable the compass check and after 2 min. flight I crashed. (my fault because of disarming the Check).
    Unfortunately I cant Upload a Log because of "error receiving log list"
    Is the COMPASS_ORIENT=12 correct?
    3702047411?profile=original
    • So now I tried nearly every combination. The best was pitch=180 for the Compass_orient(0).
      But then I got always Compass inconsistent warning.
      I give up and extend the wiring, to be able to turn the compass 180°
      • Interesting.
        I had exactly the same problem with my first M8N combo.
        It acted strangely, and I've got almost always inconsistent compasses warning.
        The warning would occasionally went away, but I wasn't confident about it.
        I thought it was a faulty unit so I replaced it with another one which has orientation none.
        It could be that 3.3 doesn't like for some reason the pitch 180 setting...
        • not only 3.3, but also 3.2.1... I have an X2 board which I needed to yaw 180deg for cleaner wiring. so for 3dr gps/compass I was trying to find yaw180/roll 180, but there is only pitch 180 which I do not believe works as after choosing this setting my mag heading is off by 45deg... It happened only recently and I contributed this to my own oversight in some settings, however after reading this post I double checked everything and it is still the same erroneous heading and "compass inconsistent" message.
          • We had a problem rotating an M8N 180deg in the roll axis....similar outcome with the heading being 45-90deg off...
            • have you figured it out?
              • Unfortunately I could not solve the problem!
                I spend nearly 2 full day to try any combination and become more and more confused.
                Also when I´m only turning the external compass the Heading in the hud does not change!
                I give up and extend the wiring!
                The compass behavior is strange and not logic from my point of view. It would be nice to have a clear Wiki, what is possible and what not and how it works.
                • what I think wiki fails to state clearly is that you set compass orientation in relation to the frame and NOT the flight controller.  Just open up your compass/GPS and fing the magnetometer chip, find a white dot on one of the corners -> for Rotation_none this corner should the left front looking from above. From here you add up all the angle as you need them.
                • Re-Also when I´m only turning the external compass the Heading in the hud does not change!
                  I noticed this too. Yet it wasn't an issue. It's something in the code I think.It's not moving... there are two compasses plus the gps reference.. so it doesn't show up as turning on the HUD [ Just guessing on this I really don't know why ]  but just from my personal experience I can tell you it doesn't mean it's not using it and don't think that necessarily indicates a problem. If you are getting compasses inconstant it means it's seeing a significant difference in the two compass headings. Try doing g a compass MOT but only go 1/2 - 3/4 throttle. After I played around with the compass MOT a couple times I was able to get rid of that warning. Good luck.
