Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          Maury,
          Ok, I have a guess as to the issue.  I think that the earth frame rate targets are not been reset when the vehicle is landed.  I've added the reset and also made the motors "slow start" in stabilize and acro.  If you're feeling a bit brave, could you give this modified firmware a try?  It will appear as AC3.4-dev but it's really extremely close to AC3.3-rc8 with the exception of these few changes.
          Note: to download the firmware linked above, I found I needed to right-mouse-button-clicked and selected "Save Link As.."
          AC_AttControl: relax earth frame rate targets along with bf · rmackay9/rmackay9-ardupilot@41a00c5
          Randy's fork of ArduPilot. Contribute to rmackay9/rmackay9-ardupilot development by creating an account on GitHub.
          • Randy,
                 I'll upload the firmware to my Multi and give it a shot over the next few hours. Let you know how it goes when completed.
            • Randy,
                   Firmware uploaded and...
              -  immediately upon power up I am now getting the Pre-arm failure - Inconsistent Compass with yellow flashing LED light. The failure can be cleared by rotating the entire multi 5-10 degree's along the Z axis and the check clears and will not return until the next power up (battery plug in and out). The error repeats at every startup. In some cases moving the multi 2-3 feet by hand laterally has also solved the problem.
              -  Bad AHRS error appears randomly and goes away. I was unable to induce the failure nor was i able to determine the solution to the failure that caused the issue to clear. The failure occurred every 3-7th power up sometimes after being powered on for 1-2 minutes. other times it was the initial failure reported through mission planner.
              -  Once I was able to get it it to arm I can confirm that the throttle response is now identical for every arm disarm sequence. across 2 15 min events with varied time spent in the air it was armed and disarmed 16 times with no issues from the motors.
              Any ideas as of to why the sudden pre - arm check failures?
  • I finally got to testing the large quad again with 3.3 RC7 after changing mounting options and ensuring throttle min was set properly and we have the same issue with it flipping. It seems to always happen after yaw inputs.
    I am completely clueless as to what could be causing the problem as when I look at the logs I don't see anything wrong and there was no mechanical failure.
    Logs attached.
    2015-07-25 16-54-38.bin
    2015-07-25 16-53-47.tlog
      Jason,
      I think it's a mechanical failure of some type affecting the front-right motor.  It's likely this motor because the vehicle flips right and forward and that motor's output (#1) goes to max while it's opposite (motor #2 on back left) goes to it's minimum.
      There's also a moment just before the flip where (perhaps due to the yaw demand) that motor goes low.  The #1 motor going low should not be a problem but it could be if that ESC isn't calibrated correctly or the THR_MIN is too low.  I see the THR_MIN has already been increased from the default of 130 to 160 so it's a bit odd - my guess is that all the ESCs should be calibrated again.
      3702582716?profile=original
  • I saw that the 3.3rc8 was out this morning so I couldn't resist, I loaded it and went to my best testing grounds to see how it went.
    I had just loaded 3.3rc7 a few days back and it worked well. On the rc 7 I was unable to test the GPS dependent modes but this tine I did.
    The wind wasn't bad but was gusting a bit and it happened to when I was arming it.  The props spin to fast when it arms.  I guess there is parameter to adjust for that, but when I arm, it is hard to keep it on the ground.  So, it tipped over.. Do damage, so I gave it a second try. As soon as I cleared the ground, it was flying very smooth and stabile.  I placed into Alt hold and it was only about 3 meters off the ground and it held it for a short time, then dropped and did a soft touchdown and then I too it back up and hovered a bit.  This time it held altitude well, so I took it up a bit higher and engaged poshold.  It was pure pleasure from that point on. It was smooth, locked in and I conservatively to simulate taking some camera shots.  In fact I was running my GoPro at 4k 15fps to explore the concept of shooting 4k to get lots of high res photos, that works well BTW!  I had one anomaly, the MinumOSD was telling me I was still in Althold, even though I was in PosHold for most of the ride.. perhaps MinumOSD needs an update..
    I had no other issues, so I really like this release.. Tommorrow I will put on the googles and do some FPV..
    attached is the Flash log
    44.BIN
      Richard,
      Thanks for giving it a try.  I think you have a very powerful copter (with a 6S battery?) because it hovers at about 36% throttle.  I see the THR_MID is set to 460 so that could be lowered a bit (maybe down to 400) to give you more control at the low end.
      I suspect you can also lower the THR_MIN value to free up more control at the bottom end.  The default is 130 (which is what your vehicle is using) but that's quite conservative.  I suspect you could lower it to 90 but that's a guess.   It depends upon the deadzone of the particular ESC being used.  If you lower this value you might also want to set MOT_SPIN_ARMED to a lower but non-zero value.  So maybe MOT_SPIN_ARMED to 70, THR_MIN to 90.
      I'm sure you know, setting MOT_SPIN_ARMED to zero means the props don't spin until you raise the throttle - this is fine, some people prefer this but using MOT_SPIN_ARMED is useful for finding out how big the ESC's deadzone is at the bottom.  So you can set MOT_SPIN_ARMED to just enough to get the motors spinning, then set THR_MIN 20 or 30 pwm higher to add more insurance that they'll keep spinning in the air.
  • Guys... I need some clarification on my vibration levels.
    Do I have vibration problems ??? I do not understand if my graphs are dangerous or ok!
    If I look only at the "grass" height I'm ok but if I look at -+3 and -+15 range i'm not. The waves in the graph are me pushing my flying limits  ( lolololol ) and of my 680 pro.
    Any enlightenment would be great because I worked very hard to remove motor / prop vibration and if I still have vibration problems I quit LOL and move on...  learn how to fish or something :S
    3702054274?profile=original Btw, first flight with 3.3 - rc8. It worked perfectly.
    Thank you very much.
    52.BIN
    https://storage.ning.com/topology/rest/1.0/file/get/3702054562?profile=original
    • Adolfo, your accel graph looks really good.  The "grass" is short as you say.  The waves are almost certainly actual flight loads.  When the Z-axis moves to -15, that's because you're accelerating at 1.5G.
      • Thank you for explaining. The flight was aggressive and that was the point. To see if I have tamed the vibrations. So to be clear, when looking for vibrations the grass height is what counts and the waves are actual Gs from maneuvers, correct?
        The wiki could explain a little better this point :D
