Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Sorry to double post but I wanted to ask this specific question again- I like to fly with just the radio and no GS sometimes, and the more insight I can get into what the copter is doing at the radio the better.  I'm hoping that the mav messages output over FrSky continues to be developed on the ardupilot side. if all of the data exists for transmission then we can bug the OpenTX crew to add support on their side.
    Anyone know if failsafe RTL is sent as the current flight mode parameter over FrSky telemetry output to T1?  I have FrSky telemetry working to my Taranis, and it is set up so it displays the T1 flight mode value from pixhawk on my screen and call it out.  If the copter failsafes to RTL, does that get sent out as the new set flight mode 6 to T1? Or does the flight mode actually not change.
    If so, then I can set up an alert in the radio if I hit an RTL event.   I was flying with only my radio and no GS so did not know RTL was invoked."
    • I don't know about that specifically but it seems like if you select RTL yourself and then see if it announces it on your TX that will be your answer right?   Or,,, perhaps I don't understand your question probably :]
      I'm having issues with my script with 3.3... it works but has some issues I noticed last night several of the data fields isn't correct or doesn't change. I think they are working on this over here http://diydrones.com/forum/topics/amp-to-frsky-x8r-sport-converter?...
      • No that is not it. I am not talking about selecting RTL manually on Ch5. That is self explanatory, right? :D
        I need to know if RTL is invoked automatically by the FC for whatever reason (fence, voltage etc), if RTL is transmitted as the new flight mode in the same manner (same as manually selecting a flight mode is sent over telemetry to Taranis.)
        • When a failsafe is triggered it changes mode just like if you had manually changed it. So, yes, it will show up as RTL in your Taranis.
          • Francisco, thanks.  So if I set up a Logical switch in Taranis to say, L4 a=x for T1, with a value of 6 (RTL mode), and then set a custom function to call out "RTL Mode" if L4 = 6, it should work right?
            The only thing odd I saw in OpenTX is for T1, when setting up a Logical switch it only gives you the choice to set numeric degrees Celsius. So I am assuming that the flight mode values coming from AC are just a numeric Celsius value reported to T1.
            Anyway, I'll test it out this next week and report back.
            • Yeah, I don't see why it wouldn't work.
              Yes, T1 is a temperature, but it doesn't matter, just put 6 there and it should work.
        • re- if RTL is transmitted as the new flight mode in the same manner
          You mean does ardupilot send the RTL verbal to frysky T1 the same as if you did RTL yourself?
          sorry just trying to clarify so somebody else can let you know. Or... I guess you could set a really safe high voltage fail safe and see what it does.
          • No that is not it- my info should be clear to one of the devs familiar with AC FrSky output, hopefully one of them is monitoring this thread.  AC does not send verbal commands of any kind over FrSky and I never said anything like that. The verbal part is handled inside the Taranis radio settings.
            • My point was is it  reported as RTL when it goes into RTL regardless of what set it to RTL. Yes.. not sure why it wouldn't.. but stranger things have happened.
  • Another try here:
    A terrible windy day, I take off in stab, then althld, pos hold, a short mission, land from the tablet mode, arm from the tablet- take off-abort and take off again from the Tablet mode, fly in pos hold simple mode, some RTLs, and all works pretty nice :O :D
    Impressive: the first time that I use the m8n, I live in the south cone far from first world so I haven't a lot espectations with this gps, It's fix 16-17 sats with cloudy day :O , I did a mark on the floor, take off-fly far and switch to RTL and the copter landed exact in the same place :O :O ; If It is repeteable, I'm going to make a mark in my club and explain Phantoms pilots why I'm the only crazy woman in the club that prefer a Diy dron with Pixhawk LOL. MANY THAAAAANKKKSSS!!!!!!
