Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          Andreas,
          I've spent some time today trying to reproduce the fall-out-of-the-sky issue using FollowMe and the only way I could make it happen was if the GCS sent impossible lat or lon values to Copter.  I can't be completely sure this is the issue but I think it's likely.  The fixes in master are here and here and these will go out with -rc10 which will go out this weekend I think.  I actually found places in Rover, Plane and AntennaTracker where this could happen as well so we've fixed them too.
          Thanks again for the report.
          • Hi Randy,
            Thanks for the feedback. I can confirm, that my followme-box works now with RC9 with the correct coordinate frame SET_POSITION_TARGET_GLOBAL_INT.
            I have also done more flights with Tower in followme mode and it worked without problems. Now I was quicker in sending take off from Tower, so that I did not have to re-arm the copter a second time, which has caused the strange immediate take off (without any second take-off command in Tower) and the crash 30s later.
        • Hi Andreas,
          The Tower tlog files can be found on your device under /sdcard/Android/data/org.droidplanner.services.android/files/tlogs/org.droidplanner.android/
          -Fredy
          Tower lead dev
          • Hi Fredia,
            Thanks for the info - I found the .tlog file from my crash with 3.3RC9 in combination with Tower in followme mode. I hope this brings more insight what happened.
            Andreas
      I've also some crash with the latest versione of "Tower", simply with a fast scroll of the parameters, annoying a lot... :)
      • Hi Marco, on which version of Tower and 3DR Services are you seeing the crashes while fast scrolling?
          The latest available yestarday on PlayStore (Asus Fonepad 7 with KitKat, APM:Plane 3.3.0).
          • Are you signed in for the beta releases?
            You can check the specific app version by going to the 'Settings' screen.
