Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Hi. I'm trying FRSKY s.port telemetry, telemetry may be sent before arming? Or is it only possible after arming?
    Thanks.
      Hi Chris,
      I use the earlier FRSKY telemetry and it is sending data as soon as the autopilot boots up.
      • Haha, while we are at the frsky telemetry (old). Please, advise what is the correct baud rate for it. I am using it on one of my machines with openlrsng setup which fully supports frsky old telemetry, but I believe due to incorrect setrinngs either in AC or in the radio I get garbage values every now and than. I've asked at the frsky telemetry threads and they say it is 56k, but MP sets the serial port to 9k when I choose frskytelemetry. Thx!
      I've actually never personally used it but from a peek at the code I think the FRSky telemetry should always be sent whether armed or disarmed.  Happy to be corrected though if someone else knows better.
  • Hey guys, I had something strange happen with auto tune today. I was flying 3.3 rc9 and having a grand ol time, but decided to go for a roll axis autotune in order to hopefully iron out a Teeny tiny little roll twitch. I adjusted the autotune axis to 2 and flipped my channel 7 switch to start autotune. Auto tune started but started with pitch... this isnt what I wanted so I killed autotune, landed and double checked the parameter via Tower. I showed 2 so I took off and tried again and it started to autotune pitch again. Thinking I might have remembered the parameters incorrectly, I changed the autotune_axis to 1 and went for it again. It still started pitch so I shut autotune off by flipping my channel 7 low again. Now, the thing that really bothers me. At sometime during all of this on and off with autotune, my pitch parameters were actually changed and my quad started to oscillate to the point of discomfort, but not enough to cause issues getting it back on the ground. I never landed and disarmed while in autotune. I never even completed autotune, but my tune was definitely altered. I really don't think it should happen like this, and hopefully there is an explanation as to why.
    Incidentally, I have never had a favorable outcome from autotune. It always yields a flyable craft, but it is always twitchy and always has to be downtuned substantially. My current quad has been manually tuned and actually flies really nice, but the same rig flown on the results of an autotune tend to cause substantial amounts of anxiety.
  • One thing I have noticed in 3.2-3.3.
    Taking off in AltHld, Loiter and PosHld, while increasing the throttle above the dead band the motors slow down for about 2 seconds then spool up and take off. Is this on purpose?
    When taking off to fly a mission in Auto mode the motors spool up and the take off is smoother and faster than the manual flight modes.
    Maybe it's just me and it is some how specific to my machine, but I thought I would ask as it is not as smooth as it could be.
