Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Marco,
      1. I've heard of some developers experimenting with the I2C ESCs but I've never used them and I don't think they're supported in ardupilot.  They are supported in the px4 stack which means we could enable the pass through but I've never done that.  The plan is more to move to UAVCAN bus ESCs rather than I2C ESCs in case that matters.
      2. PX4Flow wiki instructions are here.  I see in the MP's status screen there are some new "opt_m_x", "opt_x" values that have appeared.  I'll bet those update when the sensor is working.
      3. It's possible to bring back the CLI but it's a clunky interface and we're trying to make everything done through the ground stations with MAVLink if possible.  Any particular features you're missing?
      4. It's probably the RC is not calibrated properly.  If you set the LOG_BITMASK to All+Disarmed it'll log while disarmed and we can see if the RC is working correctly.  The MP (and other GCSs) also allow arming so you could try pushing one of their arming buttons and watch for the failure message on the HUD.
      5. pixhawk leds and sounds are on the wiki.  We're making progress on updating the wiki ahead of AC3.3 but it's not completely up to date yet - the leds and sounds have not been updated yet although most haven't changed.
      There shouldn't be any need to update the PX4 IO board separately anymore.  That's done automatically when the main FMU flight code is uploaded.  Sorry, we need to zap that last bit on that page.
      Thanks, hope this helps some.
      • Hi Randy,
        I have been flying mkblctrl quite happily on a hexa with pixhawk and 3.2. Now I have upgraded to 3.3 and the motors dont start anymore. I think a lot of people at least here in Germany have mkblctrl escs.
        Its sad that I have to downgrade now because a good and nice working thing is discontinued. I think one should be able to rely on downward compability when an update comes out.
        By the way I have your Solo and I think you have done a great job there. I am more than pleased.
        Regards
        Derek
        1. http://diydrones.com/profiles/blogs/mikrokopter-bl-ctrl-i2c-esc-sup....
          I agree that UAVCAN is better, but my ESCs have only i2c and it would be too generous of me to throw em off.
        2. Thanks. Kso... I guess I have to somehow put it on i2c bus.
        3. Debug is done better via CLI, I have to admit, that "Status" tab of MP is pretty far from ergonomic perfectness.
        4. Thanks, I'll try to see debug.
        5. Thanks again. I can help with Wiki if I'll have editing access.
    • Kinda intense topic...
      • Shoot, it really hurts to find your post with question in web search results while searching for solution :)
  • So I just swapped out my older Pixhawk for a new one hoping to get rid of the "bad gyro health".  Guess what, it still pops up.  It's not on the hud all the time, just pops up  now and again.  Maybe two bad Pixhawks?  Just connected to a small hex with a Pixhawk from about a year ago and the same bad gyro health after loading 3.3rc4.  Comes on for like 10 seconds and then disappears.  So all three autopilots are getting the same message.  No error message in the flight data logs and when the message pops up in flight and it doesn't seem to make any stability difference.  Do you think I'm safe to fly?
      We're hot on the trail of this issue.  It's related to timing jitter and one of the gyros is slower than the rest (it's max speed is ~700hz).  The two together can cause that gyro to miss a sample which leads to the bad-gyro health.  It's not good but we think it's unlikely to cause a serious problem.  Of course it obscures more serious hardware problems so we've got to fix it.  I'll add a warning to the top of this discussion.
      • You guys seriously rock!
  • This reply was deleted.
    • My experience with 3.2 betas and testing 3.3 it is far more stable and dependable for all standard flights. 3.3rc4 is the evolution A&M copter and very well done. I have spent the day testing on 3 aircraft with no concerns at all in any flight modes or conditions. I have 5 high School Student teams flying APM and tomorrow we will upload 3.3rc4 in their quads, I believe it to be that stable.
      Cheers,
      RB
      • You cant use 3.3 on APM,only on Pixhawk!
