Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Cool, thanks for the report!  We're planning on making Copter-3.3 the default version from the MP (and other GCSs) some time this week.
      • Congratulations to you and the Dev team! You did an amazing job.
    • +1!
  • Just had a very fun afternoon at a friend's farm with my 3DR X4 and QAV250, both running 3.3RC. I have taken advantage of IMU_USE to switch off my second dodgy IMU on my pixhawk and I have to say the results of that + 3.3RC + M8N are astounding. Absolutely rock solid. FPV was a delightful experience - I felt confident to go pretty much anywhere and everything worked 100% perfect. It was quite an eye-opener to compare the peformance of the M8N on the X4 with a 3DR LEA-6H on the QAV-250 - night and day in terms of stabilty, position holding etc. The QAV flew very well as well and was a lot of fun. Kudos to all concerned with the 3.3 development.
      Hi Andy,
      Good to hear people are starting to use arducopter on the 250's!! I am glad you are enjoying it!!
      • Hi Leonard - all thanks to you :)
        I'm interested in your COMPASS_MOT values. For the internal compass I have values of 50 on the X & Z access. Yes that's 50. Yours are much lower and yet this is the same frame. What could be generating so much interference? Could it really be the ESC's? I've carefully twisted all the motor wires, so I'm a bit perplexed.
        Even on the external I have values of around 5 for X & Z which still translates into something largish at 20 amps.
          Andy,
          I haven't seen your parameter file but I just wanted to check that you're not using the throttle based compassmot.  The throttle-based method (as opposed to the current based method) uses a different scale so the numbers appear much larger.  The thr method is also much less reliable because the compass interference is linear with current but not linear with throttle actually.  We're planning on removing the thr method for Copter-3.4.
          • Hi Randy,
            No I'm using the current version - although I have to say I'm not 100% convinced abut the data the ACPS3 is spitting out. Here's the current weirdness - I calibrated the compass with the battery connected in order to try and get an accurate baseline. This resulted in a calibration that EKF did not like at all - at 1.0 pretty much as soon as I wave the copter. So I calibrated without the battery connected. The EKF liked this a lot. Connected the battery - and it still was happy. No idea why. One question - I'm assuming COMPASS_MOT is switched off during compass calibration? I've started explicitly turning it off when I calibrate just in case.
              Andy,
              The compass-mot isn't switched off during compass calibration.  In fact, in Copter-3.3 the vehicle code doesn't even know a compass calibration is going on because it's all done in the mission planner.
              I guess you could check the "current" that's being reported to the ground station using the MP's Quick or Status screens.  If it's over an amp that's probably not good.  A number of "50" in the compassmot numbers means that it thinks there's a lot of interference.
              • Ah ok, that explains quite a lot :)
                Is there a mavlink message to turn it off? Might be worth recommending to the GCS folk.
                As you know I have a current meter that reports high values when the battery is not connected!
