Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
thanks Paul-
That is the acceleration in the vertical axis.
You might see spikes when you bump the ground?
thanks Rob
Hello all,
A crash apear on my octocopter but I don't understand why...
I have see the log but I'm not an expert of log review and I can't define the source of the crash.
(The log notify a first crash but it's just an error of me on the take off the real crash is the second one.)
Version is AC3.3rc12.
Thank you in advance.
I hope my experience will also help other people.
74.BIN
Hi Ruchat,
You have a massive motor output mismatch. It looks like motor 4 is struggling.
Sorry to hear about your crash!!
Hello,
Thank you for your analyis I will check my motor 4.
Have a nice day.
Sorry my ignorance, How do you detect that motor 4 is the problem there?
Hi Cala,
I am plotting RC out there and in a steady hover the lines should be pretty much on top of each other.
I can see Ch 4 is a problem because it is much higher than any of the others. You can also get similar problems if your arms are twisted.
@leonard - good info thanks- i did a 9 min flight with RCOUT logged and they all overlay on each other. suggestion, maybe in 3.4 the "default" log bitmask should be the one you recommend? that way new pilots having questions will already have the needed log data to post here.
I see now that my increase in Z axis vibe (up to 80 at some points), is directly in relation to altitude climb events. so either my bells have vertical play or the arms are flexing. but it's not seeming to affect flight behavior, the only thing I'd like to tune out is some bobbling in poshold mode. it seems to bobble a bit too much even with slight to no wind.
