Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Lots of dittos on the appreciation
  • hi
    just tried 3.3 from 321   all flies great on previous settings  after calibration only problem is in loiter mode when i let go of sticks quad flies on for about 6 to 7 meters after letting go of sticks in any direction yet in drift mode its like its hit a brick wall when i let go of sticks is there a setting that could affect this?
    yet loiters perfect when just hovering no user input
    cheers stuart
      Hi all Pos Hold vs Loiter fans,
      Both use the same code when you are sitting there without touching the sticks. The difference happens when you start to move around.
      Pos hold goes from Loiter on that axis to your stick angle and goes through a breaking procedure when you let go of the sticks.
      Loiter has a almost perfectly smooth transition with no discontinuities. This lets you make very slow very precise changes in position. Loiter is also always controlling the position.
      Most people won't notice the limitations because of the way they fly and their tendency to avoid the conditions that really let loiter shine. If I am landing in a bunch of trees with 40km/h winds gusting to 60km/h  in the presence of rotors and turbulence. There is only one mode to take the stress away.
      • All things to be better are going to be welcome but Pos Hold and simple mode is after and before for me; great work :D :D ....I'm the president of Pos Hold fans club ;)
      • Thanks Leonard- Really good to know how these modes work under the hood and the design differences in flight characteristics.
        So I gather, from your take on things, that "PosHold" kind of stands for "Piece of sh** Hold"?   wahaha  ;p
          Hi Kurt,
          I am not a big fan of Pos Hold but every mode has a place and this one was a very popular addition.
      •  Thank's for clarification
        That's Loiter better than Pos hld to land in that conditions?
      There are actually parameters that can be used to adjust the slow-down speed.  I haven't played with them yet but they come from the Solo people.
      WPNAV_LOIT_MAXA = 1000
      WPNAV_LOIT_MINA = 90
      WPNAV_LOIT_JERK = 940
      WPNAV_LOIT_SPEED=900
      Hi stubugs,
      Loiter doesn't break like pos hold. Loiter is designed to drift to a stop like stabilize does. The intent of loiter is it should resemble stabilize on a calm day no matter how windy it is.
      So when you let the sticks go it slowly drifts to a stop. If you want it to stop quicker you need to reverse the sticks in the same way you would in stabilize.
      Hope this makes it clear.
      • +1 on that - There is absolutely no reason (AFIK) to use Loiter mode any more with the new Position Hold mode available. You Devs did a **fan-freaking-tastic** job on this new mode, so thank you.
