Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thank's for all the time that you and other devs dedicate to help users too; here I posted last photos from my copter and things to resolve yet, any suggestion is welcome :) http://diydrones.com/forum/topics/optimizing-my-first-cuad?id=70584...
Hi Cala,
That copter is a quad but your log here is an Octo. I am confused.
No problem
Hi Cala,
sorry.
I got you mixed up with Rochat.
Glup!! I don't have an octo, I'm going to check
You refer to autotune one? https://www.dropbox.com/s/cmp0aogu0zeyij0/2015-10-07%2018-22-27.log...
I checked and looks the correct log, perhaps something bad configured?
Or you refer to Ruchat octo log?
(sorry if I confused something, english isn't my native language)
In 3.3 is there a way to do live vibration testing, one motor at a time? It would be great to be able to do this without having to strap a cell phone running a vibe app to the copter and running motor test... Even if it was a small utility app that one could run the motors one at a time or run test that would cycle through each on and then report out the results... Just an idea.. Maybe it exists already and I haven't found it...
I think to really take this up a notch would be to add an external three axis sensor that could communicate with the pixhawk at the motor location. You'd bypass all the extra harmonics and frame interaction. You know, now that we're throwing ideas out there lol! I've been using a Vortex balancer for a few years now, but this would be a lot simpler.
thanks for all the great work the AC3.3 is now more vibration resistance. If 3.4 has this feature than it is not only tolerate but even help reduce vibration.
one more +1
How did I know you'd be agreeable to this idea? :)
Great idea! I have often held the copter from below [ on first set up ] and in stab mode throttle up until it just about holds it's own weight. You can tell right away if one or more motors are not spinning right or being controlled correctly by moving the copter around a bit by hand... it should of course fight anything making it out of level. I also point each motor down and compare all of them for vibrations. Seems like it's not unusual to feel one motor and or prop still needs some work. You idea is probably a bit safer than what I have done!
