Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • I don't know if this helps, but whenever I plug in the USB and also have the flight battery hooked up, the USB voltage is added to the flight pack voltage. so whatever voltage is showing, say 21v for example, as soon as the USB is hot from the PC the voltage display goes up about 4v.  Unplugging USB the pack voltage goes back to normal correct reading.
        so whenever i am calibrating pack voltage reading and making adjustments, I do it via 3DR telemetry to MP.
      Hi Joe,
      Could you add some photos of your test setup and some details on how you are doing your reference measurement.
      Thanks,
      • Not too much to show.  I am measuring at the power module input solder points.  Using a multimeter to measure voltage.  The power module is mounted in a copter.  Components are stock 3DR with exception of the power module BEC not being used.
  • hi, is it possible to connect a brushless gimbal (not servo!) to my APM?
    thanks for any help.
    • answer is yes and no ! only Storm32 BGC supports the Pixhawk can be connected in that way! all other BGC must be connected to RC Rx directly.
        BTW, we also support the AlexMos gimbal using serial but we've never documented how to do it.  On the Pixhawk side it's very similar to the set-up for the SToRM32 but I'm personally unsure where to connect the serial lines on the gimbal controller which is why I haven't documented it.
        • Hi Randy, is there any progress on the Z1 Tiny2 gimbal to connect to AC?
      • Hi OG, that's not correct, pixhawk supports almost all gimbals:
         http://copter.ardupilot.com/wiki/common-cameras-and-gimbals/
        • Hay Fnoop! well that why I mentioned Yes and No !
          One channel that's can be used for tilt only ! not support at all ! Alexmos, Mrtenez and Tarot also have other channels ?  there are 3 channels 3 axis on a gimbal?
          Storm32 is supported fully! all other brush less gimbals are not supported as pas thru!
          • Hi OG
            I just checked to be sure.  3 channels are supported, there are even pretty pictures to setup in the GCS :)
            I've used AC-Copter 3.3 with Storm32, Alexmos and three gimbals with pwm support only (Tarot 2d, Feiyu mini-3d, Zhiyun Z1-Tiny2).
            Z1-Tiny2 is the most super awesome gimbal btw :)
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
