Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Thanks so much for taking the time to look into this. That makes sense because it could explain the current spike at the start of the event. These are fresh motors and ESCs so I will contact KDE and see if they can help with analysis. Are the mag fluctuations during the event due to the spin?
    • not completely sure, but it looks looks like both compasses went crazy due to a current spike.
      those large setups do need compasmot.
      • Thanks for looking over the log. I saw the the mag reading and suspected the same thing. I got a little anxious to see if it would fly and did not take the time to do the compasmot. I did switch to stab with no regain of control but I was near panic mode thinking I was about to auger in another high dollar build. Put it down in the grass with one broken landing gear so I really got lucky. We have heavy rain predicted for the next three days so I'll have plenty of time to complete the setup. Thanks for the help
    • switching into Stab mode would've given you full manual control stopping any autopilot initiated maneuvers. Also, since throttle in stab is manual copter is far less affected by vibration and absolutely not affected by bad compass, glitching gps or sudden pressure changes.
      I too learned about stab mode the hard way :)
    • I had a similar thing happen on one of the earlier 3.3 versions.
      Started spinning and would not respond to yaw after a hard maneuver.
      The problem was two fold, high vibration levels and the motors not level enough.
      This was on a folding quad, the booms pivots were wearing out allowing about 2-5 degrees of twist. Fixed the booms and found the vibration issue, flat spin problem solved.
  • Randy may I suggest an improvement for the next version of AC code, and where should I do it?
  • test flight yesterday went well. except for this:
    copter triggers battery failafe then initiated auto landing. on the previous builds, I was able to override the landing by flicking one of the toggle switches on my taranis radio. that switch is intended to override the pwm on ch5, thus setting my flight mode to stabilize. supposedly it should have cancelled the landing sequence on failsafe. but it did not..
    is this normal? or is it a bug?
      I'm nearly 100% certain that it's still possible to change flight modes during the landing sequence of a battery failsafe.  There's "de-bouncing" on the flight mode changes though so if you switch the channel quickly away and back it may not register the change.
      • I will try to repeat this sequence later. I will fly  it at around 3 meters again, then wait until battery failsafe kicks in. I just found it weird though because I have been using this "panic" switch to set it back to stabilize before. But my test flight yesterday did not yield the same result. This morning I tried flying it again but still did not cancel the landing sequence. I will try to move my panic switch to another toggle switch on my Taranis. but I'm pretty sure my taranis is working fine, it's almost new.
        Can somebody else confirm this? I hope it's just me :) the latest build is very stable.
Aug 25
