Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
OK, after reading the same discussion on Google discuss, it seems illogical to not show then the geofence check box with the arming checks check boxes; and then when the user se!ects disable pre arm checks, it should uncheck also the geofence check and show it visually.
The current way it is managed in 3.3.2 is an undocumented behaviour change versus previous 3.2.x and causes confusion. My proposal is above: be transparent and inform the user with explicit messages in mission planner.
!? Where do you read disrespect toward developers? Read twice and have some respect yourself for non native English speakers who might not be able to express themselves with your demanding stylistic language nuances. Can you do the same in french ? Go ahead.
Cheers,
Randy Bachtell
Thx happy now :)
Bravo !
I had 2 smooth fligths with 3.3.2 in Stab/altHold/PosHold, all ekf in green. It was testing flight for our last quadcopter, and we reach our new flight time record: 45min without payload. Behaviour was good even with throttle for hovering as low as 33%, and full throttle in Stab mode was scary, 2.5kg racer is not usual :)
Next big test is tuning same large quad with regenerative breaking activated on 6S, I guess I will have to lower PIDs...
Good Morning (=
I have done some testing with AC 3.3.2.
Maybe I found some bug. Maybe.
1)I attacched 3 compass 1 internal to the PixHawk and 2 to the I2C.
I can start the compass calibration, but it read only 2 compasses.
The strange thing is that it seems that the data by external compass 1 and external compass 2 in a certain way interferes with each other.
If I disconnect one of the I2C connection all work right, and I have no problem with compass calibration.
2)Landing Gear Function with AC3.3.2.
If I attach and configure the Landing Gear it happens that at the boot of Pixhawk the Landing gear goeas up.
After the boot is finished, the Landing Gear goes down.
But why at the boot the Landing Gear goeas up?
Maye the PixHawk emit HIGH PWM signal at the boot?
It happens with Radio ON also with radio OFF.
So it does not depend by the radio or the switch position.
I had tryed in so many ways but always the same result: gear up at PixHawk boot.
You can not use 3 compasses. The 2 external compasses have the same i2c address [this can not be changed until the makers of the units pull their heads out and allow us to set the i2c address ourselves] and since they both have the same i2c address the flight controller can't control them. Where did you see that it was a good idea to try to use 3 compasses?
I WISH I could get my gear to go up or down using the hawk. I have to attach mine to my RX directly and just use a switch on my Taranis. Works fine but still annoying.
I do not see that is a good idea using 3 compasses XD I simply would like to test. I like to test new things. So after the test I reported it.
About the landing gear. Any solutions?
