Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • Hi I us the gimble channel and rc 7 to make my landing gear go up and down
          Stuart
  • Hello .. got a bit of problem after changing one of my ESC that burnd out .. i alsow updated to APM:copter v3.32-rc2 and having some problems that im not shore how to fix.  the copter feels werry unstabel and hard to keep altitude . i have tested to change  both trottel midhold.. and manual tune it.. always making it wors so i hade to go back to standard . auto tune is a no go sins i cant get althold to work agen.. i some times get BAD ACCEL HEALTH. after i upgraded to this verson .. it might have somthing to do with im using a clone im not shore..
    .. maybe some one could have a look on my log.
    frame is H4 quad  670mm
    3108 700kv sunnysky  with 12 inch carbon props
    multistar 4s 8800mAh batt.
    Pixhawk clone  ..
    2015-12-11 15-51-53 5.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3702141473?profile=original
    • Did you calibrated your ESC's after adding a new one?
      It could be that the new ESC is out of sync with the others.
      That would be the first thing I would do after changing one of the ESC's.
      • thanx Igor .. yes  i did calibrate the ESCs..
        I have bin looking around here on the forum now for any thing simulare.. starting to belive its the cold wether.
        but i dont know sins i have not hade it up flying good before the cold wether started here,
        maybe some one could confirm  that if i disable the 2 IMU it would  be better ? no when this cold wheter fenomen for pixhawn happens dose the craft become unstabile?
  • Hi,
    I am no longer able to connect to my Pixhawk via Bluetooth using Mission Planner since the 3.3.2 update.
    I am using a HC-06 Bluetooth module and it is configured properly. The "Reset APM on USB connect" is unchecked.
    The bluetooth connection works using Tower Android app.
    I am running the latest Mission Planner.
    I have set the baudrates on my PC bluetooth serial port correctly to 57600.
    What could be the problem?
    • My Bluetooth connection also doesn't work any more after updating Mission Planner 1.3.32 to 1.3.33.
      Worked again after downgrade to Mission Planner 1.3.32.
      I'm using F2M03GXA bluetooth module.
      I somebody could confirm I would open a ticket in Guthub.
      • confirmed. First thought is was my bluetooth driver, but as you are saying, version 1.3.32 works!
      • I did some debugging on 1.3.33 code.
        Seems that when mission planner try to open serial port, it runs some fix port routine and also tries to write data to the socket. I assume that it does make sense for some scenarios but for bluetooth it just kill the po port. Commenting this lines do open the Bluetooth with no issues.
    • It's worth checking the other serial settings on that port - I had my serial settings reset by a recent firmware upgrade (I think).
      • ok, I think it's related to my windows bluetooth driver..
