Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Hello, with the CES 2016 Announcement of Multi point cable Cam and Follow Me Free Look, is that something that would be available earlier in Pixhawk as a flight mode as opposed to the SOLO App? thanks in advance
    https://3drobotics.com/ces-3dr-drone-2016/
      You can already do spline waypoints which is essentially like the 'cable cam' and free look camera with ardupilot, without the companion computer. The cable cam feature on the solo adds ease-in and ease-out to flight speed. That would be cool to add to missions in ardupilot.
        Yes, that's true but Solo's "cable cam" also controls the gimbal though and allows the user to pull back on the sticks to control the vehicle's position along the virtual cable I think.
          I don't mean to say it's anywhere near as refined as what in the solo it's just something similar.
          • thanks for the Response Bill but i think Randy answered this question succinctly enough! the feature really does alot more than just adding waypoints, which i was aware of.
      Thor,
      No, I'm afraid those features are in the Solo's companion computer and are closed source.  It would be nice if it was all open souce and that could be done if a community developer went and re-implement many of those features in an open source way within ardupilot but for the moment, I think the dev team has it's hands full with lots of other things.  I think it's also fair that manufacturers using ardupilot (including 3DR) be able to differentiate themselves with features that specifically suit their market niche.
      • thanks Randy i was hoping you and your team were involved in it in some way and i could get a sneak peak earlier...ok i lied i wanna use those features NOW! :P thanks for the response Randy
  • Any chance we can implement additional battery monitor simultanesly ?
    https://github.com/diydrones/ardupilot-wiki-issue-tracker/issues/154 http://diydrones.com/group/apmusergroup/forum/topics/how-to-monitor...
    You may notice that Copter-3.3.3-rc1 is now available through the Mission Planner's beta firmware link.  It's a fairly minor change as you can see from the changes below (and Release Notes here) but any testing would be appreciated.
    I must admit it got dark before I was able to test fly the exact firmware that the MP is dispensing but I will tomorrow morning and report back (I'm 99% sure it's fine but you might want to wait 15h just in case).
    Changes from 3.3.2
    1) Restrict mode changes in helicopter when rotor is not at speed
    2) add ATC_ANGLE_BOOST param to allow disabling angle boost for all flight modes (requested by XCraft whose vehicle provides lift when leaned over)
    3) add LightWare range finder support
    • OK, for a first time, I think, ever, I got an error from MP software claiming 'query error' when it tried to download firmware.
      I just updated MP to latest beta and tried to flash 3.3-rc1 it fails every time it tries to get a firmware file.
      It is same error for quad and hex.
