Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I'm still not able to calibrate properly..
I had APM 3.4 on it.. So, to start I put px4 back on it. Ran through all the calibrations. Took off and flew for a min.. No problems.
Put APM 3.3.3 on it. Same issues.
I calibrate accels. It doesn't save the settings. I do it again. It does save.. My HUD is spinning. Do it again. It works! Reboot. It works! Reboot again, "bad gyro health", reboot one more time "Accels not calibrated".
I don't know, but it seems to me like maybe it is not properly saving the values after a calibration.. Or it does, but they become corrupted after rebooting.. Maybe that explains why it worked after one reboot. Had bad health after the next, and the settings were totally gone after the 3rd.
Someone suggested I try today's 3.4 master build, and it does seem better!
It is remembering my calibrations after rebooting.
I still get bad gyro and accelerometer health warnings, but maybe less often... about 1 out of 5 times I get no errors and can arm.
I'm happy to test things and provide logs if it would help.
Otherwise, I think my original question is answered.. It's not quite as ready as some were implying, and my board is most likely fine.
Thanks!
Scott,
That all sounds very bad. There are differences between Copter-3.3.3 and Copter-3.4-dev but the low level drivers all the same. I think it's too early to be sure that it's a firmware issue.
In any case, I've created a new discussion for discussion about the Pixracer with Ardupilot so could you post a binary log file over there so we can try and get to the bottom of this?
I'd like to push out Copter-3.3.3 as the official version in the next day or so. Has anyone given it a fly and can confirm that it seems ok or not?
We will do a special build so pixracer will be officially supported using Copter-3.3.3 at the same time.
I want to mention, so my logs and info don't get lost in the chatter...
I did successfully load APM, and fly with it.
It's just that the compass settings sometimes get lost/erased if I hook it up to the computer.
And, I get gyro and accel prearm warnings most of the time.
I'm wondering if this is possibly issues because it is in development, or if these things should be working, and I should look in to an RMA?
Edited to mention, I have the same issues in MP and QGC with the config not saving (it goes through the steps, but then keeps saying I need to calibrate the compass). No problem installing the developer version of the software.
We think the pixracer should work. I don't believe there are any known issues in the software.
I know there was a change to the board's design (before it was mass produced) to move which (SPI?) bus the eeprom was on which could be related to the issues saving parameters. Or it could be unrelated... for example if the compass was not being reliably detected at startup then it could also lead to the "Compass not calibrated" pre-arm check appearing.
Can someone help w/ pixracer APM support? This isn't exactly 3.3 related, but seems like the best place to post. (And sorry for double posting, I already mentioned this in the pixracer blog, but don't think I can attach logs there)
So, my pixracer seems to function properly w/ PX4. I haven't flown much, but it sets up/calibrates ok.
APM doesn't work. I think I am narrowing down some of the issues to the USB connection (I have used different cables/ports, etc)
I plug the board in to my computer. Program it w/ Qgc using APM alpha. It programs fine. I calibrate. It goes through the steps, but doesn't save. I look at the parameter list, and the offsets are there. But, it keeps telling me I need to calibrate the compass.
I disconnected the USB, and calibrated it over the telemetry modem, and the settings saved!
But then, I get "bad gyro health" and "accelerometer unhealthy" (or something similar) 9 out of 10 power cycles.
And finally, sometimes all the compass and accel calibrations are lost. What's strange to me is my RC config and tuning remains, but the compass and accel settings are all back to 0's in the config. I think this (cleared settings) only happens when plugged in to USB. And it seems to be when I unplug from USB, it reboots the board, and the next time I plug it in those settings are gone. And again, I have tried different cables and ports, and even 2 different computers.
Logs attached. First one is when I enabled logging and was getting the gyro health error. The second one is after unplugging the board, rebooting, and my compass settings were gone.
2016-02-08 14-44-49.bin
2016-02-08 14-45-58.bin
I just ordered one myself I hope I don't go through the same issues.
So are you saying it seems to work okay with the PX4 firmware but not the APM firmware? Hopefully it's something that just needs tweaked in the settings. Please post back here or over at http://diydrones.com/profiles/blog/show?id=705844%3ABlogPost%3A2170... if / when you figure it out. I would suggest emailing them directly over there at sales@auav.co Hope it gets sorted out I was going to be running 3.4 dev myself. Have you tried 3.2 or 3.3? Do you have a gps with external mag? Perhaps disable the internal and see if that does the trick??
Cheers,
Randy
Well, I am using, or rather 'testing' the alpha version of 3.4 and having these issues.
So, I'm still not sure if you are saying 3.3 should not be working, because you are correct.. It is not supported yet.
Or, are you saying the developers know that even 3.4 alpha is not working?
The people involved w/ AUAV have been saying on another forum, that APM 3.4 alpha should be working.. It's fine if it isn't, and I understand development means it could work one day and not the next.. I'd just like to know.
And Richard, px4 loads and calibrates w/out any problems, but I had issues w/ it too.. That may be simply my inexperience w/ px4. I can't arm and take off in any mode other than manual, which is a problem if I want to be in acro and immediately take off and race in acro or something. And, I have had issues disarming in modes other than manual. Just sitting on my workbench, I can be in alt_hold (or altctl is what they call it) and put my throttle stick bottom left and it disarms. But, out in the field it doesn't always. Other quirks like that...
27
28
29
30
31
of 449 Next
