Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Sorry Randy - forgot to attach the logfile.
    In this log, I was flying in RC controlled mode, always connected to Tower.
    I landed, disarmed, then re-armed in Tower, pressed Takeoff and went into FollowMe. Then I pressed Pause and the drone immediately banked away. I could rescue by switching flight modes on my RC. (in panic I switched to Auto for a split second - this was not the reason)
    I reproduced this in another flight, after pressing Takeoff in Tower, I pressed Pause when the drone banked away again.
    I would classify this as a "flyaway" kind of defect. AC3.3.2, latest Tower release, Lidar enabled.
    Thanks for looking into this.
    84.zip
    • Hi Stephan,
      Do you also have access to the tlog files for this issue?
      - Fredy
      Tower lead developer
      • Hi Fredy,
        I am currently on a business trip- will get back to you by Thursday
        Thx Stephan
    • Tried this today with fw 3.3.3 and tower app.
      Just to make sure that I did everything the same way:
      1. Armed in stabilize and took off
      2. switched to pos hold
      3. switched to follow me in tower
      4. walked around with the drone following
      5. switched to pause in tower
      The drone did what it shoud - it stopped in Loiter.
      Did this error only happen when drone is armed via tower?
    • That's a little dramatic :)
      • Well for someone less experienced it would have likely ended crashing somewhere in the wild.
        So yes, I would consider the incident serious.
        • Apologies, the f-ing forum software truncated my answer again..  I was also  trying to say that the term 'flyaway' seems to be used for circumstances where you lose complete control of the craft and nothing you do regains control.  There are lots of circumstances where it can behave unpredictably or erratically in various automated modes (toilet bowling, gps glitches, various recovery or failsafe actions, gcs bugs etc etc) but if you can flick it back into stabilise mode and regain control or into RTL and have it return, then from what (little) I understand then this isn't classed as a 'flyaway'.  In guided mode you're somewhat at the mercy of the GCS, although it's possible it's a bug in the guided mode itself.
          It's an important distinction - phantoms are well known for proper flyaways where it's impossible to regain any kind of control, whereas it's extremely rare in APM (not bashing phantoms, just an example that comes to mind).
          • fnoop dogggiee lost interest reading your comment past your name and first sentence. But i still did....
            What Stephan is experiencing sounds very troubling. And you are not helping ANYONE with your comment. If you want to help try to reproduce this issue yourself with logs to see if more people see this issue and not just BLAH BLAH BLAH and BLAH
              Let's all cool down here.  No more comments on this until I review the logs please.
            • Thanks for your intelligent contribution.  As you can probably tell I chose my name specially so people who sound like moronic teenagers with room temperature IQs can feel superior to themselves.
              To Stephan and the rest of the thread apologies if I didn't come across well, I was just trying to be helpful but guess I didn't achieve that.  Actually I did spend quite a bit of time looking at the log - as I often do in the background to try and learn about bit more about the inner magic of the firmware.  Relevant EKF looks OK at the time, it's worth noting you have reasonable vibrations at times and a bit of clipping but I don't think that's relevant to this issue, but around about 4900000000us there's a sudden yaw and change in direction.  My kung fu isn't good enough to tell why exactly and point fingers so I just tried to point out that it's not uncommon for this to just be the FC doing what the GCS tells it to - it doesn't look like a fault, it looks like a deliberate change, and there's no indication of an error or failsafe from the FC and there's no modechange so it implies this comes from the GCS - I don't know how to read the GCS commands so I can't say for sure.  Hopefully Randy will be able to actually tell you what happened.
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
