Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I can confirm this. (often the bad gyro health 'report')
Randy,
The last time this occurred it was because of slow loops due to new code. Although not much has changed it is a recompile and some things have changed - I wonder whether this is a timing issue again and whether you need to adjust the loop timings.
Which parameter take the place of INAV_TC_Z in arducopter 3.3
Antonio,
I think it's EKF_ALT_NOISE. I personally never change it but I think that's the one.
Thanks for confirmation Randy, I searched and finally this morning I found it in other 3d
I have some problems of altitude loss
For copter this is correct that 3.2.1 is the last version that will load on APM, but plane is different. I think AP 3.3 is the last that will load on APM
If it's only happening on the desk then it's most likely just some metal around that's causing interference. Not sure what version you were on before the upgrade but we haven't changed much regarding the compass in any of the Copter-3.3.x releases.
Hi, :)
we just upgraded two hexacopter from Copter 3.3.2 to 3.3.3 .
The first connection and flights shows different behaviour than with the former version.
1* Do we have to re- calibrate the Pixhawk's after this update??
Also it took very (!) long to make the AUTOTUNE procedure.
At a landing in manual mode the copter bumps slightly up and down a few times before coming to rest.
In RTL mode, a copter bounces very hard up and down.
2* What parameter makes this bouncing happen?
Another copter suddenly shows compass inconsistency (with disappeared with a compass re- calibration).
So.................... shoud we re- calibrate all again?
Thanks for some input regarding this questions :)
The changes in the firmware from Copter-3.3.2 to 3.3.3 are incredibly minor and really shouldn't affect flight performance.
I wouldn't expect the sensor calibration to make any difference and shouldn't be necessary. Some versions require a re-calibration of some sensors (like Copter-3.2.1 -> Copter-3.3.x requires re-doing the compass) but it's not a general rule and certainly shouldn't be required for the Copter-3.3.2 -> 3.3.3 upgrade.
12
13
14
15
16
of 449 Next
