Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • T3
          Randy,
          just out of curiosity, can you elaborate a little more on that. What is the difference between hardware and software filtering reading fight performance etc.
          Thanks!
          Thorsten
            The problem is the data sheets are not very clear on exactly how the filtering is done in the hardware. On the Pixhawk we have enough processing power to do the filtering ourselves where we know exactly what is happening. This lets use exactly the same filtering on different sensors.
            The new filtering has actually reduced the delay slightly, making our control loops a little faster.
        • It's possible to fix in 3.2.1 for poor people that doesn't have pix yet? :D
            Hi Cala,
            While the clipping is a problem for both the apm and the pixhawk, this is a pixhawk only problem.
            • Thank's Leonard
        • And 3.3 RC3 exceeds my expectations.
          I hope that with further improve rc4.
          Thank you very much for your interest randy
  • And I thought to change something in my antivibration system.
    Can we rule out hardware ploblema ?.
    I hope to see you soon RC4 to test it thoroughly.
    thanks
      3702564675?profile=originalJuan, your log shows some "whiskers" but overall the vibration levels are fine.  I'd expect that you vehicle's alt hold is fine.  It might improve slightly with -rc4.
    For those few people who were seeing "whiskers" in the IMU logs, Tridge/Paul R/Grant have found the issue.  It was caused by a timing issue between the MPU6k and the Pixhawk and could lead to occasionally missing or duplicate accelerometer values being read from the MPU6k.
    Here's a video of the sophisticated testing setup.  At least we know the Australia dev team hasn't strayed from it's DIY roots!
    • T3
      Poor magnetometer! ;-)
