Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
RC7.
This hexa aircraft act like an angry mosquito on steroids!
It did starts this ekf-2 error. Don't know (what it is) or why.
bin file included.
Just for info: Flew without any vibration on 3.21.
Did not even take off. As soon as a bit of throttle is applied, it want to go up very very nervously!.
Thank you in advance.
bin file for above
2015-06-30 08-20-04.bin
Sorry for so many posts. Here is the download link to the log mentioned. It was just outside the native upload limit.
http://1drv.ms/1Hr8iaR
Just to compare Artem's (correct) interpretation of the IMU data, I checked out the new VIBE message. It also shows the vibes are many times higher than my IRIS and more seriously there's a lot of clipping on both the primary and secondary accelerometers.
no wonder your copter jumps up and down :) your vibes are waaaay over the head.... check all the bolts, make sure that your frame is structurally intact and that your props are balanced.
If using case, make sure your board is not "dancing" inside or if the whatever mounting option you use did not come undone.
My props are well balanced and everything seems secure, but I will give it a good once over to see if I can find anything that would be contributing to vibes. I guess there is no reason delving into this further until I can get the vibes in line.
please elaborate on the alt jumps on x2.... are you using foam/case or not.....
I though it only was my old x2....
I have x2 on 2 systems with rc7 and other than certain altitude drop during fast flying it has no jumps or unexpected movements.
If I let it be on its own it recovers altitude to what it supposed to be. Drop of altitude is usually apparent when it is lower than 3m or so, may go down 2m or so, then crawl back up. there is foam on the baro, on both cases.
I also believe all parameters should be left exactly as autotune sets them, for best performance. there is one parameter people were writing about here - ATC_ACCEL_Y_MAX - boosting it up from autotune value resulted in extremely sensitive vertical movement in stabilize mode and it made practically impossible to set drone to sit on a constant altitude in stabilize, in my case I moved it from 17000 value to 27000 value.
But it did not affect behavior in the alt hold at all.
Hi Paul,
Especially with rc7 I think people should generally only drop the ATC_ACCEL_X_MAX values unless they want to have very aggressive handling.
The parameters
MOT_THST_BAT_MAX
MOT_THST_BAT_MIN
MOT_THST_EXPO (0.65 to 0.75)
MOT_THST_MAX
should be set by the user before autotune.
