Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Randy Bachtell,
I am very sorry to hear your copter was destroyed. I am afraid that I gave you bad advice. The redundancy of your hex appeared to be tolerating the motor loss. I suspect it was the specific advice to increase the Thr_Min that made the difference.
This is definatly motor sync problems and is often caused by Simon K esc's. Sometimes it can be fixed with settings on the ESC, other times it requires different ESC's.
Again, I am very sorry for your crash and the bad advice I gave you that contributed to it!!!
Please PM me if you have any questions or help and I will do my best to help.
Pardon my ignorance but not sure how to PM you. I would like to contact you for advice on the rebuild and not jam up the discussion.
Thanks to all,
RB
Man, I've experimented with SO many simonk/blheli ESCs/6s/high pole count motors... I can tell you one thing.... both blheli and simonk can be made to run smooth with those motors, however, at 6s, the measures both blheli and simonk take to keep up sync, take huge toll on ESCs and require adequate ventilation. In some of my experiments, where I limited mount of airflow over ESC to none, 40A rated ESCs heated up all the way to 112 deg. C (yes, C) on ly at 6amp load. The best ESCs I found so far for the 6s+high pole count/low kv motors are Hobby Wing xRotor Pro 40A. regular xrotors 40a are good as well, but the pro ones on the same motors/props/battery/frame/flight controller give noticeably better wind performance and reaction time and allow to run higher PIDs, while remaining at ambient temperature.
+10 on the HW XRotor 40A ESC's. Every HW ESC I have ever used has been good, and the Xrotors are fantastic. I use them on a large Octo with 15" props running 6S on 320kV motors. Never a sync problem and they only get barely warm, even with zero airflow stuff inside the booms.
Haven't seen your logs, but it sounds awfully like sync loss :( ..... Did you bench testsed you ESC/motor/prop/lipo combo beforehand? During ATT firmware request very fast and large throttle changes, many simonk/blheli ESCs combined with h high pole count motors could loose sync, also are you running the gnd wires from each ESC back to pixhawk?
Someone else's VIBE messages looked very different mine, here are mine:
Hi Andy,
In my experience so far the Z vibrations are much worse than the X and Y. And these look ok.
Staying below 10 most of the time is good. Spikes up to 40 seems to be ok. Anything averaging around the 20 to 30 mark is nasty and spikes above 60 is in danger of clipping.
I'm seeing very high vibe numbers also on my 450 quad. Yet the IMU Accel numbers don't look that bad. It seems to be flying OK but then, this is the only one I've ever flown so I have nothing to compare it to. Maintaining constant altitude in Stabilize is really challenging so maybe it's due to the high vibe figures?
Hi Roger,
When flying in Stabilize you arn't using the accelerometers for anything other than the calculations of your roll/pitch/yaw angles.
Are you using a smooth throttle stick or do you still have the ratchet on. This is one of the big reasons some people have trouble with throttle control.
Leonard:
Actually I just checked & I do have a light ratchet effect on the throttle, so I'll get rid of that.
Thanks!
