Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Oh that's just great. The latest beta Tower crashes often on my Samsung Tab Pro.
Also, when using RTL, upon landing it switches to Loiter mode......I don't have a Loiter mode set up on the radio and made no such command! It can then be re-armed and take off with throttle up in what I assume is Loiter (it sure isn't Stab). What I don't recall is if I had to switch out of RTL on the radio before arming. I thought there was problem with rc9 at first, but now believe it is Tower; will test with only the radio tonight weather permitting.
Having the tablet on my Taranis is nice instead of lugging around a laptop, but as it stands Tower is broken IMO. It really needs to be given much attention because a lot of Solo users (I had one) are not content with the limited features out of the box and want to fly missions. The last thing 3DR needs is Solo users crashing because of Tower, and there are a number installing the latest beta of Tower to get the added features. Yikes.
I didn't tell it to switch to Loiter after landing! Is it supposed to do that?
The jumbled mess of flight modes was from using Tower to test switching modes with it (which I rarely use Tower for). It definitely flew in Auto, and when reaching the mission waypoint to land, I switched to RTL.
DG,
Are the Tower crashes consistent and replicable? If so, can you open an issue in the issues list with the steps to reproduce the crash.
The 'switch to loiter' behavior is being look at in this issue. Can you contribute to the issue with your observation as well.
Thanks!
-Fredy
Tower lead dev
DG,
Probably best to raise this in the Tower issues list. I've dropped some of the developers a note as well.
No crashes or other issues on my Nexus7/2013 to report.
With the new embedded live video feed Tower becomes a nice add on to the Solo app.
That's good news. Have you tried flying a mission or RTL?
Be aware of settings in Solo that aren't exactly ideal for MP or Tower.
50 minutes in one flight with one battery pack, mixed flight mode, ultra light carbon frame by "Andrea Beggio", "APM:Copter RC9", "Pixhawk" and "U-Blox M8N" gps.
LiPo 6S 4.6A, total weight 1400g (MTOW).
If anyone is curious here the link to the log (bin): https://drive.google.com/open?id=0B3HEcrNCOga9dHZwSUppRjFVb2c
Interesting the HDOP average (0.6), and the sats number (19), without a single glitch.
@Marco Robustini: Re you 50 mn flight.
Would you mind sharing the motors/props/esc specs?
Thank you very much in advance.
Regards
Henri
Marco,
Really amazing , 50 minutes “is a lot”……
Please can you give more details about the frame and this project….?
For more detail about the frame please contact "Andrea Beggio" via Facebook: https://www.facebook.com/beggio.andrea
Hi Marco,
thanks a lot.
And congratulations for your vídeo, really good
