Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Kenneth,
      Looks like a tlog, if you've got a dataflash log I'll take a peek at it.  If it really is baro noise, then it's a known issue on the to-do list here but there's no guarantee we can do anything about it in software actually.  The best solution is a physical change to the frame.  Here's the diydrones discussion on this topic.
      • I think the issue you linked to is a "Climb" issue and his is a "drop" issue. I've always had a climb issue since back in the old APM days and not just APM but even my old MultiWii boards. And to be honest. I have always kind of liked it :)
      • Hi Randy,
        I'd greatly appreciate it. What I notice is a very noisy IPD which looks to be caused by a very noisy baro. At least in comparison to the wiki.
        Using the 3.3 vibration tool it looks like my vibrations are acceptable.
        Here's the .log:
        https://www.dropbox.com/s/xk2klyey5tjc54m/2015-12-02%2016-28-17.log...
        Dropbox - Link not found
        Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
        • yes, your vibs looks good, It's look different than my vibes problem
    • Kenneth: I had the same issue with vibs under acceptable levels during long time but vibes were my problem at the end, be shure that isn't the problem.
      • Sloppy motor bells can also cause some of these issues.
        • I'll relook at vibrations. I've been using the Copter 3.3 Vibration tool in mission planner. I'd assume that motor bell slop would show up as vibration.
          • It would and mostly the Z axis
    • did you foam the baro? Yes even with it in a case and yes even with the RCTimer AVDome. I had similar issues with one of my hawks and it too was in an AVDome and some dense foam and a recalibration did wonders.
      Also did you make sure to adjust Hover_Throttle to match exactly what your STAB hover is in mission planner?
      BTW Tlogs are pretty worthless. You need to attach an actual .LOG/.Bin that you download from your Hawk.
      • It is a 3DR manufactured Pixhawk. Opening it up and adding additional foam was my next idea. It remains in the 3DR case under the dome.
        How do you recalibrate the barometer?
Aug 25
