Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Loaded up 3.3.2.1 on two of my birds and put them through every possible combination of maneuvers switching between modes at random, I became confused but the aircraft handled everything in stride, even with fairly heavy winds. Landing modes spot on, Nav control looks great.
      Thanks for the hard work,
      RB
    • Hi randy! I got a big problem :-( with 3.3.1 and 3.3.2 rc2 the copter takes off in loiter/althold with about 80% of throttle given by me. In stabilize it takes off with about 45% of throttle. What can that cause and how can i fit it? In the logs i saw that the thrOut is much lower than the thrIn when trying to fly in loiter/althold...
        Yup, I agree wit Nathaniel.  Just one thing.. taking off and landing in AltHold, Loiter or PosHold should work a-ok.  I take-off and land in these modes all the time.  If it doesn't work, I'm happy to have a peek at a dataflash log file.
    • 2) Fix to hard landings when WPNAV_SPEED_DN set high in RTL, Auto (resolved by using non-feedforward alt hold)
      ^^^ nice to see this one, i had a few hard landings myself because of it, and broken gear legs...will try first thing tomorrow!
    • Today tested AC3.3.2-rc2 on my quad-copter. It has a Lidar-v2 and px4flow.
      In AC3.3.1, I was unable to arm in AltHold when FLOW_ENABLE = 1. It happened the GPS reception is also bad (so bad it couldn't pass the 3D-fix pre-arm check if I armed it in PosHold mode). Now with AC3.3.2-rc2 I can arm in the same situation.
      However I crash the Tower-v3.2.0! Whenever I attempt to change the EKF_GPS_TYPE from 0 to 3, the Tower-v3.2.0 crashes. So I haven't test optical-flow-loiter in this flight.
      I use Mission planner (1.3.32.12 build 1.1.5803.19723) to review the dataflash log. I see several funny error codes:
      Err: 195-203
      Err: 193-0
      Err: 255-11
      What are they?
      3702604346?profile=original
      I fly AC3.3.2-rc2 in stabilize, altHold with Lidar-v2, and posHold. Overall very happy with it. The altHold now is very *solid* when I land it. No jumpy altitude anymore when my copter is very close to ground (less than 1 meter). Thanks to the range-finder feature!
      an unrelated question. I bought a USB-fpv-video-receiver from CUAV. It can receive video signal on 5.8GHz and stream video to smartphone/PC via USB. Can Tower display the video coming from USB?
      Thank you very much for the great work!!
        Wilson,
        Thanks for testing and sorry for the slow reply.
        I have no idea what those error messages that you've seen are.  Our highest error message is 20 so I'm unsure where 195 has come from although my guess is it's caused by some corruption in the log or a display issue in the MP.  If you have the log still I can take a peek.
        We've got a new discussion re optical flow which you've probably already found but here it is in any case.
        Feel free to report that Tower issue here.  Maybe it's crashing if it gets a message it doesn't understand although really it should have protection against that kind of problem.
        If the video from the USB-fpv system is H264 then it should be possible to get it displaying in Tower but maybe pinging the Tower guys through their community page is the way to try and get that working.  I googled for the USB fpv system from CUAV but couldn't immediately find it.  If you have a link I'm a bit interested in checking it out.
    • Many thank's Randy, load and try to test this weekend
  • Hi Leonard,
    An update on this. I have done some manual tuning on Roll using the Dave C method. The results are ok but I note a couple of things:
    Roll_P needs to be quite high for good response, its much too soggy otherwise
    Roll_I set to the same level results in unflyable oscillations.
    So I conclude that autotune will never be able to tune this copter if it sets Roll_P == Roll_I.
    Roll still feels less responsive than pitch. Not sure how I can improve this. I'm also going to try go back to simon K to see what different that makes (but with active braking enabled).
    Thoughts?
    2015-11-20 13-10-14.bin
    • I've drastically improved roll responsiveness by upping ATC_ACCEL_R_MAX. Autotune had set this to a very low value (53000), I increased it to 180000 and now the copter feels much, much more responsive.
      So the $1m question is if I now try autotune on this - which actually feels pretty good - will it make it better or worse?
      Too much wind at the moment to try it out!
