Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • Things that I noticed: Your roll and des roll didn't track in that moment, idem Pitch, so I think that your controller didn't want to flip but, perhaps a mechanical failure did it, as James said, very fast switch modes, if you didn't do it check PWM mode values, and the third thing that I notice is that your vibs looks to high and some strange thing in clips but I'm not shure how to interpret them.
          My 2 cents: check your motors/props (bearings, little shaft bolt, etc.)
          As you discover the problem, you have to practice that pirouette, now you know that your copter can do it ;)
        • You say you didn't switch to Pos Hold? How are your Pwm values? Isn't that the problem
        • dont switch so fast between modes.. make one decision ok i want this mode switch to it and stick with it for 10 seconds min.. then if you want to switch back go ahead but dont switch then switch to something else.. that might be your problem...
  • This reply was deleted.
    • Hi. I have asked for the same thing too. It is useful for those of us who use a double power system to take off as soon as the battery is replaced.
      I think it will be done for 3.4
    • AH!! that's the reason because batt Beep under time, thank's
    Copter-3.3 is out as the default version!  Thanks again to all the beta testers on this thread!
    • Installed and flew it today, all seems to be well except of gps switching between units. I ended up disabling that parameter for auto switch and then it was all fine, very stable.
      Other thing - for my armattan i set all filters to 40hz from default 20hz and it works way better this way.
      Looks like a great release.
      I think for dual gps systems a better logic would be to put in a check if primary gps unit goes completely kaput - like time update stream stops or something like that and only in this case to switch into a backup unit. This 'on the fly' switch mode should probably be removed as in practical reality it causes more trouble than good.
    • Hello Randy,
      is the version 3.3 still without mkblctrl? If so will the mkblctrl be discontinued?
      As I am using these ESCs I cannot upgrade.
      Regards
      Derek
    • Congratulations!
      So when does the 3.4 beta testing start?
      Thank you again.
      We appreciate what you do.
      Hi all Pos Hold vs Loiter fans,
      Both use the same code when you are sitting there without touching the sticks. The difference happens when you start to move around.
      Pos hold goes from Loiter on that axis to your stick angle and goes through a breaking procedure when you let go of the sticks.
      Loiter has a almost perfectly smooth transition with no discontinuities. This lets you make very slow very precise changes in position. Loiter is also always controlling the position.
      Most people won't notice the limitations because of the way they fly and their tendency to avoid the conditions that really let loiter shine. If I am landing in a bunch of trees with 40km/h winds gusting to 60km/h  in the presence of rotors and turbulence. There is only one mode to take the stress away.
