Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
The logs were still on the pc. I guess with the Lions winning today my exuberance deluded me to think I loaded the correct log. So much for fantasy vibration levels.
l
2015-10-18 20-31-08 65.bin
Now much sense, I'm near that kind of graph, you scared me ;)
DG,
Ok, yes, so about 2x or 3x the levels on my IRIS. We think things go bad when the vibe levels are over 60m/s/s so it'll probably fly ok.
Randy: What it mean clip? how to interpret?
Cala,
Clip means that the accelerometer was overloaded, the acceleration (vibration) was higher than the accelerometer is able to detect.
it looks like this: (picture from wikipedia):To the left is the real signal, to the right it is "clipped".
In apm there is a counter (clip0,clip1,..) that increases every time the signal is clipped.
How to interpret: clipping is bad and should be avoided whenever possible. It is ok when it happens while landing the vehicle.
Many thank's Lukas, very clear explanation.
New build:
H4-680 Alien frame
CUAV Pixhack hard mounted (no foam)
KDE 2814XF-515 motors
KDE 35A ESC
CUAV GPS/mag
Gemfan 13x5.5 CF props (for testing only)
AUW: approx 2.7 kg
After sorting out ESC issues, I took it up for maiden flight, just hovering around a bit. All went well except the copter has some oscillations. Before doing AT I'd like to dial it in a bit, but to be honest am not sure where to start given all the changes in 3.3.
Here are the vibration levels. Spikes in Vibe are takeoff and landing:
Link to flight log
https://www.mediafire.com/?od7ncedxv36xoi8
Doesn't look like this vehicle actually flew so I don't think we can trust those Vibe numbers. Sorry!
I can assure you it did fly. I can also assure you I used the wrong file. What a dope, will try again tomorrow since I cleared out the logs.
