Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hello,
While following the wiki to configure PX4FLOW and Lidar-Lite v2 on AC3.3.1, I am wondering when does the autopilot actually use the PX4FLOW camera. Would anyone mind to let me know if I am right or wrong in the following.
- Autopilot reads PX4FLOW only in OF_Loiter flight-mode?
- Autopilot reads PX4FLOW in all GPS-assisted flight-mode, but does not read it at all in non-GPS flight-mode?
- Wiki requests EKF_GPS_TYPE = 3 during PX4FLOW test flight. After that I should set it back to EKF_GPS_TYPE = 0 in normal flying?
- Whenever the flight mode requests X/Y position estimation the autopilot reads both GPS and PX4FLOW. EKF then blends them together for autopilot to use?
- OF_Loiter is a flight-mode that needs X/Y position estimation but does not read GPS. It only reads PX4FLOW?
Thanks for clarifying my confusion,
Wilson
Wiki says it does not use sonar readings anymore and I see flat line for EKF5.meaRng.
Lidar is additional $200...
http://www.robotshop.com/en/lidar-lite-2-laser-rangefinder-pulsedli...
It would be nice to have the option use the installed sonar or lidar, either way OF is really neat feature.
I agree, having such option would be great.
Tried to calibrate OF, but it seems without lidar flowX/Y and bodyX/Y are poorly correlated, scaling will not make them match (bodyX/Y and GyrX/Y do match).
I am interested in the answers to your questions also!
Looking forward to an icon in mission planned to enable PX4Flow as a near plug and play option, with a calibration sequence similar to setting the Acc or compass.
All is good time I am sure.
It's normal that I start autotune with
ATC_ACCEL_P_MAX,72000
ATC_ACCEL_R_MAX,72000
and after autotune I have
ATC_ACCEL_P_MAX,49814,88
ATC_ACCEL_R_MAX,51907,54
ATC_ACCEL_Y_MAX,12720,53
Tnx
Yes, these parameters are tuned on autotune routine. How are your copter flying with them?
I'm satisfied but just after second autotune The first wasn't good (autotune>save>autotune>save)
I have large x8 8 kg
This procedure was recommended a few times. The autotune takes the currrent parameters as the starting point, thus , doing it two times would make the parameters more refined.
If they are OK, with no wobbles, enjoy it!
Hi!
I tried to use battery_voltage2 and current2, readings get to Pixhawk but scaled wrong?
I received 15355V, tried to scale it to 15,3V but then I only get 15V. Using a standard power module connected to ADC 3.3V.
Want to use 2 batteries in parallell and monitor each via separate power modules?
Great job with the new version....
//Affe
