Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Stuart
17x5.5inch props
390kv motors
30amp Simonk afro esc
10000mah 4s
Pixhawk 2.4.6
Flys for half an hr
vibration levels abit high but there was a 23mph gust winds
vibration within normal levels on not so windy days
stu
sorry missread where you said you covered the entire hawk in cling wrap and not just the baro :(
you should NEVER cover the holes on the baro. Use dense foam not cling wrap.
Stuart
What Craig is getting at is that you said you cover the whole pixhawk in cling film, which is essentially the same as covering the holes on the barometer rendering it useless.
I still got height reading on mission planer
Cheers stuart
I have done about a dozen flights now with V3.3 on my littlest Pix, a 320_mm hexacopter. I had a few issues with the Autotune and PIDs on upgrade, but this thread has helped me sort those out. Thanks boyz. I have been pretty satisfied with V3.3
But, today I have landing gear and a bent arm to repair. On my last flight, it inexplicably dropped from the sky. I have tried to decipher the cause from my logs, but I don't have the experience to determine the issue. It felt like a voltage drop, but the battery had over 11_V remaining and the cells are within .1_V of each other.
Can anybody suggest the culprit? . . .
2015-11-06 17-21-17.log
