Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
yes I have M8N and 6M, and the M8N is always lower HDOP , but i have had then switch in flight with no issue, seems to work ok for me in that regard and i have tested it too (by disconnecting the TX wire from GPS into Pix via a relay switch)....but i dont think the issue am having here is related to having 2 GPS necessarily...
When in drift mode it can reach 50mph but is OK up to 30/35 mph but above that it starts to dive loosing height tried changing max angle for all flight modes to 30' but still losses hight above 35mph
could this be software or does any one think frame/mechanic have reached its limit on forward speed and power to keep nose up enough to maintain hight
It's not a barometer problem as I cover whole pixhawk in cling film to keep out wind altering pressure on barometer
Stuart
Hi stubugs,
Can you provide a log please.
Stu
hi please find attached log
many thanks stuart
2015-11-08 13-28-14.tlog
Hi stubugs,
Sorry, I need a data flash log.
many thanks stuart
2015-11-08 13-28-41.bin
Nice setup but it looks like you push the quad speed envelop to hard. Theoretical max propeller air speed with lowest measured bat voltage approx. 13.6V with 390kV motors and 5.5 inch prop is approx. 12.3m/s. To be able to move air faster increase voltage or change motors and propellers
Stuart
17x5.5inch props
390kv motors
30amp Simonk afro esc
10000mah 4s
Pixhawk 2.4.6
Flys for half an hr
