Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • Hi I us the gimble channel and rc 7 to make my landing gear go up and down
          Stuart
  • Hello .. got a bit of problem after changing one of my ESC that burnd out .. i alsow updated to APM:copter v3.32-rc2 and having some problems that im not shore how to fix.  the copter feels werry unstabel and hard to keep altitude . i have tested to change  both trottel midhold.. and manual tune it.. always making it wors so i hade to go back to standard . auto tune is a no go sins i cant get althold to work agen.. i some times get BAD ACCEL HEALTH. after i upgraded to this verson .. it might have somthing to do with im using a clone im not shore..
    .. maybe some one could have a look on my log.
    frame is H4 quad  670mm
    3108 700kv sunnysky  with 12 inch carbon props
    multistar 4s 8800mAh batt.
    Pixhawk clone  ..
    2015-12-11 15-51-53 5.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3702141473?profile=original
    • Did you calibrated your ESC's after adding a new one?
      It could be that the new ESC is out of sync with the others.
      That would be the first thing I would do after changing one of the ESC's.
      • thanx Igor .. yes  i did calibrate the ESCs..
        I have bin looking around here on the forum now for any thing simulare.. starting to belive its the cold wether.
        but i dont know sins i have not hade it up flying good before the cold wether started here,
        maybe some one could confirm  that if i disable the 2 IMU it would  be better ? no when this cold wheter fenomen for pixhawn happens dose the craft become unstabile?
  • Hi,
    I am no longer able to connect to my Pixhawk via Bluetooth using Mission Planner since the 3.3.2 update.
    I am using a HC-06 Bluetooth module and it is configured properly. The "Reset APM on USB connect" is unchecked.
    The bluetooth connection works using Tower Android app.
    I am running the latest Mission Planner.
    I have set the baudrates on my PC bluetooth serial port correctly to 57600.
    What could be the problem?
    • My Bluetooth connection also doesn't work any more after updating Mission Planner 1.3.32 to 1.3.33.
      Worked again after downgrade to Mission Planner 1.3.32.
      I'm using F2M03GXA bluetooth module.
      I somebody could confirm I would open a ticket in Guthub.
      • confirmed. First thought is was my bluetooth driver, but as you are saying, version 1.3.32 works!
      • I did some debugging on 1.3.33 code.
        Seems that when mission planner try to open serial port, it runs some fix port routine and also tries to write data to the socket. I assume that it does make sense for some scenarios but for bluetooth it just kill the po port. Commenting this lines do open the Bluetooth with no issues.
    • It's worth checking the other serial settings on that port - I had my serial settings reset by a recent firmware upgrade (I think).
      • ok, I think it's related to my windows bluetooth driver..
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Monday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
