Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
RobC,
The logs seems ok to me. What makes you think it's corrupted?
RobC,
The format of the logs has changed a bit vs AC3.2.1 but I'm able to open the logs with the both mission planner (official and beta) and AP2 on windows. The to-do list for AP2 is here, perhaps raise an issue there.
I'm using APM Planner v2.0.18-rc2.
I've run into a few issues with the new lots. 1st it times out when trying to load them into the Auto Analysis with a popup box that just says "Time" and then another popup saying "Bad Input File" and when trying to load them into Kev's Log Analyzer it also errors saying "Log must be created by an Ardu Vehicle firmware!"
I just tries again with Paul's a few posts down and it now says "Exception of type 'System.OutOfMemory.Exception' was thrown" then "Bad Input File"
This is using MP 1.3.30 and Kev's 2.1.0.9
There is TOO much log it seems for the apps to handle. The PC is x64 with 32gigs of ram so it is not a PC issue.
Same thing happens to me on MP 1.3.35, windows 8.1. When i click auto analysis for a log i get two messages
The type initializer for 'NumpyDotNet.NpyCoreApi' threw an exception
Bad input file
I can't analyse any logs!
Craig,
Ah ok good. At least some of these are "known issues" and all related to the log analysis tools rather than the logs themselves. We have a fix for the Log Analyser but it needs to be tested and then the MP will need to pickup the change. I'm not too familiar with Kev's log analyser tool but I suspect it needs changes as well to deal with AC3.3 log file format changes.
The size of the logs is temporary. We've increased the IMU logging to 400hz for beta testing. For the official release we will reduce that to 50hz and the logs will be 4x ~ 8x smaller (the IMU data is a large percentage of the total log size).
I think we should take this EKF dude behind the wood shed for a little talk.... lol
I think Richard is just kidding around and he's picking up on my weariness re the EKF. The EKF is a fine piece of software but is more complicated than the older DCM/inertial nav and is proving a challenge to get exactly right and there's still some learning we need to do in the wider dev team in how it's acts.
Definitely appreciate both good and bad reports re AC3.3 and we're close to the finale so we should expect it to perform very well at this point.
Alex,
You don't need a full 3D lock if you're only flying in stabilize or AltHold. Ideally bad or missing GPS data shouldn't affect the attitude estimates but I'll ask PaulR to confirm. If bad/missing GPS does affect the attitude then it's something we should fix.
I have had this happening since 3.3.2 came out. I think randy said that EKF is using GPS to determine position even though GPS is not used in Stabilize mode.
The copter flies fine except you may not have a good home position.
Doesn't always happen but sometimes.
277
278
279
280
281
of 449 Next
