Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Hugues,
        As far as I understand when servo rail power goes above 5.7, power from that rail to the pixhawk processor/electronics is cut by a switch or ideal diode or whatever.
        But pixhawk will continue to be powered from power module port (as long as it is below 5.7v)
        Is it right?
        • MR60
          Craig was not using a power module. So Pixhawk will shutdown if it sees a voltage spike on its servo rail. That is why you need to install an external zener diode on the servo rail that cuts (trim) any voltage spikes above 5.7V.
          • Correct, but I could have had a 5v bec plugged into the + and - pins on the pwr module, and that would have saved my bacon. Pixhawk would only have shut down power to the rail, not shut off completely. At least that is how I understand it now. Am i right or wrong?
            • Yes Craig. You are right
              • MR60
                The order of priority taken by Pixhawk is : 1-Power port then 2-Servo rail. The servo rail power comes into account if the power port is not used. (there is also theoritically another powering option via the USB port which is not used in flight, only on the bench).
                I have to check the theory on the bench that in case the power port is used, if you get a high voltage spike on the servo rail (even if power port was powered), the pixhawk will not reboot as this would happen if powered only by the servo rail....
      Craig,
      Sorry about you crash.  Txs for the suggestion on the pre-arm check of the servo rail voltage, I think we can add a servo rail high voltage check fairly easily (a low voltage check would be difficult because many users leave it unpowered).  5.6V seems about right?  Our main board voltage check is 4.3V ~ 5.8V but maybe we should tighten these.
      The in-air voltage check is something we've discussed a few times but haven't implemented because we thought that it wouldn't help much because when the power system goes bad, it goes bad quickly and there's little warning.
      • What if I am running 6v on the servo rails on a traditional heli. But the PixHawk is powered by the PM? Would this cause issue?
          UAS_Pilot,
          As long as the vehicle is powered through the power module then it should be fine.  It's only if you want a backup power supply through the real power rail that it's important to ensure that back power rail is less than 6V.
          If we add a pre-arm check that the real power-rail is under 5.8V though then you would need to disable that check.  We haven't added it yet though.
          • Ok.
      • Maybe have a quick look at my flight log. Make sure I am correct as to the cause of this crash. I dont want to rebuild this thing in generally the same manor thinking I have nailed down the cause of the crash just to have it crash on me again.
        thanks in advance!
        4.BIN
