Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • @Craig DeFleming
      First Issue: It's takes a few seconds for the EKF to start functioning. The BAD AHRS warning should always clear itself momentarily on the HUD.
    • I second that. I too have been patiently waiting for UAVCAN on The APM side. QGroundcontrol is much more user friendly after the latest upgrade but still a bit awkward IMO for flight modes. You can try out your Zubax gps with QGC if you are flying a quad as they have an option for UAVCAN in the frame setup.
      I will be testing 3.3 next week. Thanks Randy and team for all your hard work.
      RB
        @RB,
        We have some UAVCAN support in this release including support for some experimental UAVCAN based ESCs.  Tridge is the one who has been testing out UAVCAN for other sensors so I'll ask him about the UAVCAN GPSs.
        • T3
          Thanks!
          I am interested in testing the zubax as well. It would be perfect if the zubax compass would be supported as well.
          • I'm putting this answer here so everyone interested could see it. Here's the tutorial that explains how to make APM use UAVCAN-interfaced sensors, particularly Zubax GNSS.
            • Can the same principle be applied our custom EPM which myself and Andreas are working on? (which will have UAVCAN).
          • Thorsten,
            Have you tried to implement your Zubax with 3.3 yet?  I have tried with no results.  Zubax indicates CAN bus communication and GPS lock but the pixhawk can't use the data, so I'm not sure how Tridge set it up to work and have had no response from Dev team.  I contacted Pavel at Zubax as well and I think he is looking into it.
            RB
            Ok, so Tridge has tested the Zubax GPS and it "works nicely!" it seems so feel free to give it a try and report back!
            • I connected my Zubax GPS, LEDs on the zubax are lit but I get no GPS signal through to the Pixhawk or indication in APM Planner.  I can't find anything in the parameter list that looks like a UAVCAN parameter or to direct gps signal.
            • Perfect, what are the parameter changes needed?
              RB
