Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          The 80% rule applies to capacity, not c-rate (http://www.tjinguytech.com/charging-how-tos/80-rule) and has been a long standing recommendation to make LiPo's last. The main rational behind it is that each cell in a pack discharges at a slightly different rate mostly depending on the condition of the cell so if you discharge only using 80% of the capacity you lower the risk of draining one slightly lower performing cell below it's damage voltage (3.0V).
          With a 3 cell pack you can have a voltage of 9.5V but the cells might read 2.9V, 3.3V, 3.3V so if you fly to 3.5V per cell or 10.5V per 3 cell pack you usually end up consuming ~80% of the pack, which for those with voltage telemetry is an easy point to determine.
          80% Rule - TJinTech
          Home of TJinGuy's heli info
          • Can you give me a link to a lipo manufacturer that confirms that?
            http://www.overlander.co.uk/fullymax_warning_sheet_li_poly.pdf
            The only one on-line that I could find in a rush, bottom of the page item number 5 clearly says that it is the 80% of C rating*mah (as I described) and not 80% of the mah capacity.
            I do agree that 3.0v per cell is the absolute minimum and I personally only go down to 3.5v per cell when flying. However I regularly fly my 5000mah packs using up 4500-5000mah and have had no problems after multiple cycles using the 80% of C*mah rating (still staying above 3.4v per cell).
            Quad pulls 58-59amp max so I use 5000mah packs with a minimum C rating of 20 (100amp max supply).
            • Though a bit off-topic but I can share some data on my LiPo testing.
              I think there are 2 issues mixed together:
              1) LiPo "mAh" can be over-rated. The steep descent of LiPo terminal voltage may happen earlier than expected.
              2) LiPo "C" can be over-rated. The LiPo temperate can get unsafely hot even if current draw is within the "C" rating.
              Following is my 30A discharge testing on a Zippy 4S 5000mAh 20C LiPo.
              3702885016?profile=original
              It shows this LiPo "mAh" capacity is over-rated. The "voltage cliff" starts to occur when 4400mAh~4600mAh energy is consumed, not 5000mAh as rated.
              3702884946?profile=original
              Another plot of the same test shows this LiPo"C" is also over-rated. 30A discharge from a 5000mAh LiPo is only 30/5 = 6C. However the temperate keep raising and raising. I have to switch on my air-conditioner when the LiPo reaches 38 degree celsius. Also I turn on my fan and blowing cool air over the LiPo to cool it down.
              If I really let the LiPo be discharged at 30A all the way, I might have a lipo smoke (or fire?) in my bedroom!!
              3702885041?profile=original
              So the actual "mAh" capacity here is 88~92% of its rated number.
              And the actual "C" rating is not even close to 40% of its rated number.
              * These test is done using iCharger 308DUO. I love this charger very much ^^
              3702885114?profile=original
  • Just upgraded from rc9 to rc10 and a funny thing happened.  Before I could load 10 and had the USB cable plugged in the failsafe went off.  Very load and scary.  Unplugged the USB cable and plugged it back in and all was well.  updated to 10 and did a test flight.
    Like the serial ports coming on right away now.  Use to have to wait a half a minute or so for it to go active and sometimes not at all.  Now it seems to be right there.
    Test flight was good as always.
      Michael,
      I guess you mean the battery failsafe?  I think that means that it did not detect that the USB cable was connected.
      Are you using a Pixhawk or some other board, maybe an AUAV board?
      The battery failsafe is disabled when it thinks it's connected to the USB port.  Because of a hardware issue on some significant number of AUAV boards we've made that USB detection slightly more conservative. Previously it just relied on getting the power from the USB port but now it relies on getting both power and succesfully connecting to the laptop/desktop computer.
      I imagine what may have happened is that when the USB port was plugged in, it was providing power but for some reason USB communication was not actually possible.
      That will be a slightly crappy outcome if we've solve one problem (a work around for a harware issue) at the expense of creating problems for others without that hardware issue.
      • I had the same thing  happen.. with an AUAV board..  USB 1/2 way plugged in and it beeped loudly, like the battery alarm.  I re-plugged it and it was fine.
        I'm not sure I'd call it a problem, and would maybe just make a note in the documentation that it can happen if your USB cable is faulty.
      • This was a real Pixhawk less than a year old.  The cable I was using may be the issue since I didn't really see the port show up on the computer.
  • Updated from 3.3-rc1 to rc9 yesterday on a TBS Discovery Pro.
    Autotune results were fantastic, the end result was a lot less twitchy than those on previous versions. Very smooth flying.
    In addition, landings used to be very bouncy and the landing detector wouldn't trigger unless I switched from Loiter/Poshold to Stabilise, where I then was able to throttle down a lot more.
    Now the landings are much smoother - it still takes around two seconds for the landing detector to trigger while landing with Loiter/Poshold, but it's a lot better than before. Very happy about this.
    I did observe something strange, namely that the GPS HDOP value was at 99, despite having over 13 satellites. The position in the map looked stable as well, so I set "GPS_HDOP_GOOD" to 10000 and took off. It flew and hovered fine, so I'm not sure if:
    a) The GPS (CSGShop u-blox NEO-M8N) is defective
    b) GPS reception was bad after all
    c) It's maybe a bug introduced by a change in rc7 that affected HDOP/PDOP reporting
    Log attached.
    2015-08-27 11-50-45.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3702080835?profile=original
      Mark,
      This can be caused by the configuration messages from the flight controller to the GPS not getting through.  It may be a one-time thing or it may be because the GPS cable has been damaged.
      This weakness has been there, as you suspected, since we changed the hdop value in -rc8.
      It's possible to add a check into the driver and/or it possible to update the GPS configuration using u-center to specify the dop message is required so that it's sent even without the flight controller asking for it.
    AC3.3-rc10 is available for beta testing.  I've updated the main section with the changes.
    The changes vs –rc9 are mostly of bug fixes and safety improvements.  This is hopefully the last release candidate before the official Copter-3.3 release.
    The new EKF compass variance pre-arm check (3a) may require another release candidate because if the EKF stops using the compass there’s currently no way for it to recovery without rebooting the flight controller.  Solo-master has a solution for this that we may need to import if too many people find they can never get past the “EKF compass variance” pre-arm check but let's see!
