Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
@ Alex:
I have the EKF VARIANCE also and I went back to the 3.2.1 version because i don't trust the 3.3-rc5 yet.
@ Richard:
Where can I find the possibility to lower the settings on this (you think)
sorry Paul I'm not sure and probably isn't the best solution anyway...
No log attached? The first one you attached didn't contain anything useful.
No idea. Your log looks perfectly fine apart from this error. My only guess is that you are moving the copter while the gyros are calibrating. Make sure you keep it absolutely still when you plug the battery in.
re- I tried disabling each of the compasses but I think that the EKF check ignores this and continues to check both.
Yes I remember Randy was going to look into making sure it actually ignored the compass during the initial checks if that was selected.
DIY tricopter question: I loaded 3.3-rc5 today (coming from 3.2.1)-- have there been changes to the Yaw mechanics? My yaw is now very sluggish/spongy in responsiveness. And it does not stop quickly when the stick is released, it slowly yaws to a stop (alt hold/stab/pos hold). Sometimes making a complete 360 if I'm making an aggressive turn and let go of the yaw stick. Reset everything to defaults/recalibrated/etc... same result. It used to be very aggressive in trying to hold/stop at the position when the yaw stick was released.
Hi Michael,
This is probably the Rate Yaw Filt number. If you increase it to 40 this should fix your problem.
I am trying to get a tri built now so I can support the tri pilots better.
Hi Aleksey,
No, leave that at 5Hz and experiment with increasing Rate Yaw P. Auto tuning Yaw should also help but I am making some changes that should improve things a little for yaw. These changes should be out in the next release candidate.
I had to increase YAW_P and _D drastically on my monocopter too. A question: does increasing these parameters beyond the range specified in Full Parameters List have an effect?
Hi Peter,
For most of them yes.
349
350
351
352
353
of 449 Next
