Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Ok, after more investigation, my brand new landing gear controler is simply death...
            Thanks you for your help, really .
            • maybe is something wrong with wires..
    • Yup, works great  for me :)  I'm using the standard tarot retract controller from the 650sport (which I believe also comes with most of their other current frames).  The only thing it doesn't do as advertised is to automatically retract the gear after takeoff, it has to be retracted by rc switch.  But it always deploys for me automatically when landing or rtl.
    Copter-3.3-rc7 should be available through the mission planner's beta firmware link in about an hour.
    We think this at least partially resolves the attitude estimation problems that Winston, RobertS and Peter Barker (on another thread) found.  Still, we recommend staying on -rc5 until we've had more time to be sure. We're pushing out this version because we believe it's safer than leaving a clearly broken -rc6 in place.
    If you do feel brave enough to test -rc7 please be on the lookout for attitude estimation errors especially in the first minute of flight.
    Changes since AC3.3-rc6:
    1) reduce EKF gyro bias uncertainty that caused attitude estimate errors
    2) force 400hz IMU logging on (temporary for release candidate testing)
    Sincere apologies for the troubles and thanks for helping us test so these types of troubles don't spill out into the larger community!
    • T3
      Hi Randy,
      I had two successful flights with rc6. The second however started a little strange: After arming and while still on the ground, the copter showed massive wobbles/oscillations - similar as with wrong PIDs. Then after disarming and arming again all was fine. Sounds like it is related. Send me a PM if you are interested in the log.
      Best regards,
      Thorsten
    • Hi Randy,
      I guess I will be surprised if this is actually the source of the problem. I am running rc5 with close to these values (1e5 rather than 8e6 in GBIAS_PNOISE) and I don't see this massive oscillation. Here is a graph from wednesday with rc5. You can see that the overall changes are very small and the oscillation occurs around a mean that looks close to what you actually want. I suppose the increase in uncertainty could be the culprit (I didn't change the default), maybe the initial perturbation throws everything off? If it stop raining I might experiment a little to get more data.
      3702576743?profile=original
      • So I ran tests with rc7 with GBIAS_PNOISE set to 1e5, 8e6 and 1e6 respsectively. I can't say that rc7 felt any different to rc5. The learned offsets looked pretty similar to what I was getting with rc5 and control seemed good.
        It was fairly gusty but the copter coped fine and the EKF innovations seemed ok. I couldn't see any difference in roll/pitch/yaw between DCM and EKF. The logs are pretty large because of the IMU logging so I won't post here. I guess a theory might be if you have high vibrations then you will be more susceptible to bad gyro bias learning.
        I did notice two unrelated things:
        1. You can't set GBIAS_PNOISE in tower, it thinks the value is effectively 0.
        2. I still see very aggresive throttle up with RCMAP. Spin on arming does not work for me and as soon as I touch the throttle the thing tries to take off.
        Graphs below. Let me know if you want me to plot anything else.
        3702706366?profile=original3702706447?profile=original3702706387?profile=original
          Andy,
          Thanks a lot for testing this and all the other things you've been doing.  I also never had a problem with the higher GBIAS_PNOISE values from -rc6's so it seems to only affect some copters and is likely a combination of some waggle, compass noise plus this param change.  That's what I've heard from Rob/PaulR.
          I'll have a look at the RCMAP + spin-when-armed issue.  Txs!
          • Thanks Randy,
            I debugged the spin-when-armed issue a little last night and was kind of able to reproduce it in the simulator. It doesn't seem RCMAP related though, which is weird. Basically I put in debug to print out RCOUT on 1 channel every second. What I see is the following for different values of RCIN, with MOT_SPIN_ARMED set to 70:
            RCIN     RCOUT
            1000      1000
            ARMED 1070
            1001      1070
            1010      1070
            1020      1070
            1030      1135
            1040      1145
            So I think the aggressive spin-up I see is when it goes from 1070 to 1135 with RCIN only changing fractionally. It seems to be something to do with the minimium pwm value being set to "130" (I guess this gets added to radio_min), but I don't understand why the spin-when-armed value is allowed to be below this. I had some success modifying AP_MotorsMatrix::output_armed_not_stabilizing and I think that's where the problems lie, I'll have another look this evening if you don't get to it first.
              Andy,
              I tried to reproduce any issue with spin-when-armed + RCMAP and couldn't so I agree with your finding that perhaps it's not spin-when-armed related.
              While doing this I wondered if perhaps people were forgetting to do the RC calibration and/or ESC calibration after changing RCMAP parameters.  I'm planning to write a wiki page on RCMAP so I'll add this requirement to the instructions.
              The spin-when-armed value should be below the THR_MIN because we want the motors to spin at a lower rate when the vehicle is landed so that it's less likely to injure people.  Once it's not landed the thr-min ensures the props don't stall.  So I think the parameters involved in this are:
              RC3_DZ (where "3" can be different if RCMAP is used) : the deadzone on the throttle input.  By default "30".  this explains why you see a jump when the RCIN goes to 1030 - below this level the pilot's throttle input is considered zero (or "1000" pwm).
              MOT_SPIN_ARMED: this + RC3_MIN (where "RC3_" can be a different channel if RCMAP is used) is sent to the motors when the vehicle is landed + pilot throttle input is zero (in stabilize mode).
              THR_MIN: this + RC3_MIN is sent to the motors when the vehicle is not landed + pilot throttle input is at minimum (i.e. 1000pwm) OR vehicle is landed + pilot throttle is above minimum (i.e. > 1030).
              When the output is jumping to 1135, it must be that the vehicle thinks it's not landed.
