Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • A little bit of topic but as I am on my first Pixhawk and 3.3RC7...
    I recently bought an external led and usb board (not from 3DR as they were out of stock)
    My problem is that if I connect it to the I2C port or as the only one on the I2C splitter the led works ok, but as soon as I connect the compass (or anything else on the I2C splitter) it stops working.
    The only thing I found about the problem was a faulty splitter, so I tried with two more but with the same result.
    Any clue what could be the problem?
      It could also be a power issue.  Maybe the flight controller doesn't have enough power for both devices.
      • Randy,
        I do have a two battery setup on the 650sport (for the video stuff), will try to power it from the second battery.
    • I think that i2c LED has the same i2c address as your compass.
      • Artem,
        Is there a way I could change it (on a compass)?
        Its a compass/gps M8N combo.
        • As far as I know nope.
          But as Randy mentioned it could also be a power problem, however I think if it is the case, than it would also power down the whole 3.3v line on the FC board meaning that your gyros, acc and the onboard compass would be malfunctioning.. Also, as far as I know most of the m8n GPS/mag combos are powers through the 5v line of the GPS serial port,,,
          • You are right.
            I have connected only the SDL/SCL/Ground wires from the compass to the I2C.
            The power is coming from the GPS port.
  • Something of possible interest. Frame- Hoverthings Flip FPV w/ 2212 980kv Sunnysky's. I have been flying a 3s setup with 11x45 HQ MR props for a while now. Last night I switched over to a 4S setup with 9x43 HQ MR props. IMU1 is nearly identical with either setup but the big difference is in IMU2. With the 3S setup, IMU2 is sometimes very erratic. So far (only a few flights), the 4S setup has IMU2 in check. I still have some tuning to do, etc..., but just thought I'd toss this out here as something of possible interest.
    3s
    3702045074?profile=original4s
    3702045321?profile=original
    • T3
      To me the relation between the two looks more or less similar.
      But what is interesting is that IMU2 is that much higher. On my setups it is higher as well but only a little. Most probably this is also related to a specific frequency.
    • MR60
      The difference you see is due to the smaller props on 4S: they turn faster and thus the frequency is different (higher) than on your3S setup. This shows your anti vibration mount does not blocked lower frequencies as well as higher frequencies.
