Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Sorry to become a little bit OT.
    I just build up a new Copter, because of my Taranis Issue.
    I use a GPS N8M which I have to mount in its opposite direction. See Picture!
    COMPASS_ORIENT=12 (pitch180) and did my Compass calibration with MissionPlaner.
    Sometimes the Compass show North (the Copter front looks to North) some times East or West. Of course I can´t Arm the copter. I disable the compass check and after 2 min. flight I crashed. (my fault because of disarming the Check).
    Unfortunately I cant Upload a Log because of "error receiving log list"
    Is the COMPASS_ORIENT=12 correct?
    3702047411?profile=original
    • So now I tried nearly every combination. The best was pitch=180 for the Compass_orient(0).
      But then I got always Compass inconsistent warning.
      I give up and extend the wiring, to be able to turn the compass 180°
      • Interesting.
        I had exactly the same problem with my first M8N combo.
        It acted strangely, and I've got almost always inconsistent compasses warning.
        The warning would occasionally went away, but I wasn't confident about it.
        I thought it was a faulty unit so I replaced it with another one which has orientation none.
        It could be that 3.3 doesn't like for some reason the pitch 180 setting...
        • not only 3.3, but also 3.2.1... I have an X2 board which I needed to yaw 180deg for cleaner wiring. so for 3dr gps/compass I was trying to find yaw180/roll 180, but there is only pitch 180 which I do not believe works as after choosing this setting my mag heading is off by 45deg... It happened only recently and I contributed this to my own oversight in some settings, however after reading this post I double checked everything and it is still the same erroneous heading and "compass inconsistent" message.
          • We had a problem rotating an M8N 180deg in the roll axis....similar outcome with the heading being 45-90deg off...
            • have you figured it out?
              • Unfortunately I could not solve the problem!
                I spend nearly 2 full day to try any combination and become more and more confused.
                Also when I´m only turning the external compass the Heading in the hud does not change!
                I give up and extend the wiring!
                The compass behavior is strange and not logic from my point of view. It would be nice to have a clear Wiki, what is possible and what not and how it works.
                • what I think wiki fails to state clearly is that you set compass orientation in relation to the frame and NOT the flight controller.  Just open up your compass/GPS and fing the magnetometer chip, find a white dot on one of the corners -> for Rotation_none this corner should the left front looking from above. From here you add up all the angle as you need them.
                • Re-Also when I´m only turning the external compass the Heading in the hud does not change!
                  I noticed this too. Yet it wasn't an issue. It's something in the code I think.It's not moving... there are two compasses plus the gps reference.. so it doesn't show up as turning on the HUD [ Just guessing on this I really don't know why ]  but just from my personal experience I can tell you it doesn't mean it's not using it and don't think that necessarily indicates a problem. If you are getting compasses inconstant it means it's seeing a significant difference in the two compass headings. Try doing g a compass MOT but only go 1/2 - 3/4 throttle. After I played around with the compass MOT a couple times I was able to get rid of that warning. Good luck.
                    The issue with the heading not changing when the external compass is rotated is usually because the EKF has given up on the compass because it's movements do not match the movements of the gyros.  This is a good thing if the vehicle is in motion but I can imagine it's annoying in this special case where you're trying to figure out the compass orientation.  The only way to get the EKF to start using the compass again is to restart the board.  If you move the compass very slowly the EKF won't give up on the compass I think but changing the compass_orient parameter probably will upset it immediately.
                    I think looking at the raw compass outputs (see mx,my,mz and mx2,my2,mz2) in the mission planner's Flight Data screen's Status tab is the way to go.  When I was recently doing it with JulienB/Tridge for the Parrot Bebop I compared the raw compass outputs to what my working Pixhawk output.
                    Also this wiki page has some advice for figuring out the orientation (search for "Quick Setup Procedure") although the EKF giving up on the compass may make this difficult to follow.
