Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Attached is a log from a crash using 3.3 rc5,
Couldn't find the reason yet
https://drive.google.com/a/visioncortex.com/file/d/0B5QeAqGnP_rYNkQ...
Raviv
Raviv,
Looks like I need permission to download the log file..
My bad, Its open for all now.
Thanks for taking the time.
Raviv,
I've had a look at the logs and it looks like a failure of the back right motor (#4). I think it's this because the actual roll and pitch are following the desired reasonably well but then suddenly separate. The throttle is not very low at this time so there's no reason to suspect it's the THR_MIN issue reported by IvanR.
By the way,. there are other bad things happening in this log which makes me think the vehicle has very high vibrations. Could you please upgrade to AC3.3-rc7 which includes the new VIBE message, do a short flight and post the dataflash logs here?
The issues are the DCM vs EKF attitude estimates are off by >10 degrees and there is a portion in the log just before the crash where the vehicle's climb rate is negative but the baro and sonar alt appear to climb.
Thank You!!
I will rebuild it and post the log
Looking at the logs it seems that you were on the ground most of the time. Then when you did fly your VCC dropped a LOT as did your volts on your main pack. Your PDOP is all over the place and it looks as if you were moving it around a lot while it was initializing. It's kind of hard to read these logs all in all but all these things adding up looks like a crash was waiting to happen.
Sorry for my bad english.
3.3 RC 7 is pretty cool only gps is extremly slow.
I have configure ublox manual over passtrough all is fine 2 minutes for hdop under 2,3.
When i disconnect the battery for 20 seconds i wait 5 minutes an have hdop over 3
In u center i see all my config is @ m7n settings this is bad
The gps modul is on a tower than comes the level only with pixhawk than comes gfk under this the battery and power modul than comes gfk and under this is the power distributor. All my flights was outdoor.
Only after configure with ucenter without battery disconnect i have 12 sats @ cold start in max 2 minutes. After disconnect the battery and reconnect i see in u center under gnns config all unchecked under rates 1hz 1000ms.
I store the config in bxxx and Epprom
By the way, in the dataflash log's UBX1 and UBX2 messages there's some additional info including a jamming number (see field "jamInd"). Not sure but these may also provide some additional information when the GPS signal is facing interference from nearby electronics (like FPV equipment).
here the log
over the complete fly no good hdop in complete free area hundrets of meter nothing
http://1drv.ms/1Ok35lP
i cant open this file in MP
is a 500er Frame
