Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • @Pit do you mind sharing a copy of your M8N parameters from ublox ucenter software ?
          How to:
          You need to save it as .txt
          Open ublox ucenter , menu tools -> GNSS Configuration -> GNSS to file
          thanks
          • hello manuel
            thanks, yes, when i´m back from my Travel i will do it.
            Manuel,
            Marco's M8N parameters can now be found here in github.
            • Randy, just to let you know that using Marco's config file did the trick !!!
              That or the change of GPS_TYPE to Ublox. I did those two at the same time, so I dont know for sure which made my quad fly well again
              Thank you!
            • Thank you Randy
              If I'm not able to 'save' my GPS unit by loading these parameters from another unit, what's the next step ?
              I mean, I've only changed a few parameters within ublox ucenter software, how can that make a gps useless :|
        • @Pit. +1 here for M8N from CSG shop. I have 6 differents large M8N on different multirotors. They are really good here in east cost of Australia.
          And the "new" improved ground plane incorporated (see photo) looks like a good way to isolate a it the electrical noise from "below".
          All my M8N are mounted much higher than the main "platform" where electrical noise is common. I do add a sandwitch aluminium/copper plate under the GPS. The M8N are located about 15 to 18 centimeters away (above) from main noise sources. They *all* are powered with *clean power (read: Not switching one) This is much better than ferrite filter. Never had a GPS glitch so far in any of the six aircraft. Could it be purely coincidental? :-)
          • hee henri, no i think its not a coincidental. look, its my copter with the large CSG GPS. Works fine and i have 3 UBEC for powering the PIX. I think a clean construction its importend. U are right!
            Today i will make a test with RC9
            3702848937?profile=original
            https://storage.ning.com/topology/rest/1.0/file/get/3702849122?profile=original
          • What's the diameter of that round one ?
            • About 10 centimetres (3.937007874015748031496062992126 inches) :-)
          Yestarday, HDOP 0.7 (VR M8N)...3702795917?profile=original
