Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Wilson,
Sorry, I actually downloaded your log when you first posted but didn't complete the analysis.
I think the lean is caused by the poor GPS location. The NSat is really very low at only 5 or 6. I think the GPS position was drifting around but it wasn't bad enough to trigger the glitch protection.
The EKF also reports a spike in velocity and position variances around that time. I'm not very familiar with the units of these variances so I've asked Paul Riseborough (EKF expert) and we shall see what he says.
I don't think it's caused by the low battery itself because the desired and actual roll/pitch values stick together.
Thanks Randy for looking into my issue~ ^^
My landing/take-off point has poor GPS reception. This location is surround by tall buildings and a hill of 100~200 meters height. So I switch to alt-hold mode when I attempt to take-off and landing, expecting to be unaffected when my copter is flying through this "bad GPS air-space".
Does autopilot or EKF continue to use GPS information in alt-hold mode or land mode, maybe for correcting X-Y coordinate?
Thanks a lot for your help again~~
Wilson,
Yes, when the failsafe triggers it will try to use the GPS unless it's had an EKF/GPS failsafe. So the GPS position must be quite bad for it not to use it. In your case this is not great because the battery failsafe triggered a GPS controlled land while the GPS quality was not great because (I guess) it was descending in the shadows between buildings. It's a bit tricky to handle this case.. I think we would need to tighten up on the GPS requirements but that could cause problems in other areas like when we set the home location or do the pre-arm checks. I'll discuss with the dev team but I don't immediately have a solution.
Thanks Randy for your explanation.
So is it possible that when failsafe-land kicked in, I was actually fighting with the EKF/GPS? Maybe EKF/GPS was pushing the copter forward and my RC2 was pulling the copter back?
If this is true, I think the situation maybe avoided as follow.
- in failsafe-land mode if there exists pilot input on RC1/2/4, stop listening to EKF/GPS and listen entirely to the pilot input
- in failsafe-land mode if there is no pilot input, listen to the EKF/GPS
That is giving pilot command the highest priority if EKF/GPS and pilot are both "talking" to the autopilot at the same time. With this my copter would have entirely listen to my RC2 pitch-back and wouldn't lean to the front by itself.
RC10 has something changed again in the GPS department I guess as I flew it today and it was very erratic compared to rc9. RC9 was almost ideal, this RC10 flight today was nothing like it.
with rc9 I did not have anymore HDOP 0 or 99.99 issues - with RC10 I had 99.99 stuck HDOP on first GPS unit for 3 power-ups consequently, plus during flight drone was wondering from location to location way more aggressively than with rc9. may be it was a solar storm today, who knows, but I kinda doubt it as with rc9 on same field I always had RTL to return within 50cm from the take off point, and today RTL did a wild hunt for landing spot with a 20m arch going left and right at aggressive angle, so I had to drop drone down to the grass which I did not have to do once since rc5.
so it was a bit unexpected. Did you by any chance reverted GPS code from RC9 into old from RC8 as Rc8 used to behave like that.
here is log file. Both GPS units were from 20 to 19 sats with good link from what I can see, overall vehicle attitude was horrible compared to hw RC9 behaved, it was constantly jerking from one position to another, so, I bet something was altered.
If there is a plan how to make it work better I think it has to be a priority now, as it was close to unusable today and for no obvious reason.
here is a link to log file.
https://www.dropbox.com/s/ypsdkieixdp4blf/20.BIN?dl=0
K Index indicates all is quiet
Others on RCgroups have given similar reports.
I would suggest you try it a few more times and see if some days are better than others.
Paul,
Yes, totally agree that disabling the 2nd GPS is not the ideal solution. It's on the to-do list to fix for AC3.4 so I'm sure we will sort it out in the coming months.
