Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
yup im getting a green lite on the pix now..
im getting bad velocity but before i was a yellow.. so now im sure it will fly... 3.3 has bugs that need to be fixed and looked at
auto analysis doesnt work anymore? is something wrong on my end? I get pop ups saying 'time' and then 'bad input file' but the logs open fine when i review them. Also im using the latest beta mission planner
Parachute function test was success with firmware 3.3. Test sessions covered two manual ejects and two automatic recoveries. One motor were killed mid air by cutting power off using relay. In this blog you'll find more info.
how much weight those it all add up?
very cool!!!!
I flew 3.3 c12 tonight and flew in alt hold and pos hold and both were improved from 3.2 I think. Alt hold was more consistent even in yaw'ing and or tight circles. Previously my quad would gain in one direction or lose in another before but now it's just... well ... awesome. I then flew around in pos hold up to and round 15 mps and noticed a more consistent posisition hold and braking to stop position. Not a huge gain over 3.2 but seemed more consistent. Smoother would be the best way to describe it.
The biggest improvement for me was seen when I chopped the throttle from about 45 meters and it dropped like a rock BUT was completely stable without the wobble from the prop wash that was VERY apparent with 3.2. NICE!!! WOW!!!
Just a side note I didn't do any auto tune after updating to 3.3. So it was very apparent to me even without that it was much improved.
I didn't do any auto.... But the two main things I want't to see improve did!! Altitude. [ over water this is critical ] and pos hold.
But perhaps the best thing to mention or note for me is NO errors mentioned. No EKF or Compasses inconsistent or anything. It just fire out of the box sweet.
RK
Hi Richard,
What are the specs of the craft you were flying? Thanks -
Fred
Give or take it's a 550 quad I built myself with 1100KV T motors and a 3s 5200 batt. I use and all in one ESC. A Taranis set up .![3702721808?profile=original](https://storage.ning.com/topology/rest/1.0/file/get/3702721808?profile=original)
Nice setup. Thanks. Never seen battery connectors like those before: what are they?
Traxxas, good for at least 120amp current.
I use them on a 6cell erevo brushless and my friend on his 3cell slash 4x4 with mamba conversion.
