Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
switching into Stab mode would've given you full manual control stopping any autopilot initiated maneuvers. Also, since throttle in stab is manual copter is far less affected by vibration and absolutely not affected by bad compass, glitching gps or sudden pressure changes.
I too learned about stab mode the hard way :)
Started spinning and would not respond to yaw after a hard maneuver.
The problem was two fold, high vibration levels and the motors not level enough.
This was on a folding quad, the booms pivots were wearing out allowing about 2-5 degrees of twist. Fixed the booms and found the vibration issue, flat spin problem solved.
Randy may I suggest an improvement for the next version of AC code, and where should I do it?
Artem,
Sure, enhancement requests/suggestions should go into the issues list.
test flight yesterday went well. except for this:
copter triggers battery failafe then initiated auto landing. on the previous builds, I was able to override the landing by flicking one of the toggle switches on my taranis radio. that switch is intended to override the pwm on ch5, thus setting my flight mode to stabilize. supposedly it should have cancelled the landing sequence on failsafe. but it did not..
is this normal? or is it a bug?
I'm nearly 100% certain that it's still possible to change flight modes during the landing sequence of a battery failsafe. There's "de-bouncing" on the flight mode changes though so if you switch the channel quickly away and back it may not register the change.
I will try to repeat this sequence later. I will fly it at around 3 meters again, then wait until battery failsafe kicks in. I just found it weird though because I have been using this "panic" switch to set it back to stabilize before. But my test flight yesterday did not yield the same result. This morning I tried flying it again but still did not cancel the landing sequence. I will try to move my panic switch to another toggle switch on my Taranis. but I'm pretty sure my taranis is working fine, it's almost new.
Can somebody else confirm this? I hope it's just me :) the latest build is very stable.
That's mean if the copter decides to Land for failsafe and you switch to another mode the copter abort land and fly in that mode?
Cala,
Yes, that's right. It pretty much never ignores the pilot's requests to change the flight mode unless it's impossible to enter that flight mode due to poor GPS.
the copter responds to switching to stabilize in overriding the Landing sequence now if i use the flight mode switch on taranis. but when i use a toggle switch which i programmed to override the ch5 pwm, it does not work.. no switching from landing to stabilize. at least now i can confirm that the overriding still works
83
84
85
86
87
of 449 Next
