Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
It's not Vortex Ring State. Something much more dramatic.
Vortex Ring State causes your drone to 'sink' like a yo-yo, even though you give it full throttle to pull out. (until you bounce, stably, off the ground, breaking the vortex ring state, followed by your drone shooting right back up into the air). I've had it, and there are videos on Youtube.
In your video, just before the onset of chaos, it sounds almost like a snapping sound. Can you be sure the broken-off motor in your 'after' pic broke off on contact with the ground (and not in the air?). Even if it dangled, still 'wired up', all the way to the ground?
George
Re-watching the video, I'm more convinced there's a distinct little 'snapping' sound at :43 seconds - like the sound of snapping your fingers.
Followed immediately by chaos.
George
What are the red motor mounts made of? It looks to have broken off at a narrow point. Consistent with hitting the ground, of course, but also where I might expect failure under sudden strain of full-throttle. Speculation.
George
Speaking of speculation - where was the black cat at the fateful moment?
George
Any motor mounts of mine that have failed (or needed replacement because they were at risk of failing), did so at roughly that same location - where they join the arm, often via a stretch of material that is narrower than the rest of the mount. Even worse, manufacturers compound the problem by cutting material out of the mount nearby, further concentrating the stresses. I guess it looks cool.
It begins with stress-weakening, barely visible (maybe just a local discolouration), then hairline cracking (still easy to overlook), then sudden, catastrophic snapping.
I make my own mounts now, and I avoid that narrowing phenomenon entirely. It's trouble.
George
From your last log file of the actual spin out your RC Out 1 lost traction causing the value to max out, see graph. I would just hold down the quad and test the motor using the Pixhawk motor test at 100%. I don't know what the purpose of the simulator is when you already have one built in. Once you can identify it and reproduce it on the ground follow standard troubleshooting by swapping one component at a time. Don't over look the power distribution board. I just had an integrated one go bad on my Tarot 680 Pro hex driving me batty for a few days. One motor was slipping poles at > 65%. Good luck.
re- log confusion... I have that confusion myself MANY times. Sometimes they are listed in a different order on the SD card than on my HD which makes it easy to make a mistake.
Hi Dave,
The log you provide doesn't appear to be from your crash. Can you please give us that log.
Hi Dave,
Those errors don't mean this is your crash log. I am 99.9% sure (I am never 100% sure) you have the wrong log. Nothing matches your video.
Hi Dave,
I am looking at the correct log but it doesn't show any yaw spinning. I am pretty sure you have uploaded the wrong log.
66
67
68
69
70
of 449 Next
