Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
https://drive.google.com/file/d/0BzWH4Q7IAU5YWTJwLWRQTklXRVk/view?u...
So I need raw IMU logging? I thought that we had turned on high speed logging by default for RC7, and this is was basically the same thing?
Rob, these vibration look extreme. My copter would complain :-)
But yes, the vibes are relatively low. Maybe it is the low-pass filtering effect of the vibes/stdev. But this should not be that dramatic.
Yes, exactly, the vibes are quite high by the old measure. But low by the new measure. That's why I'm questioning if the new vibe logging is measuring the right thing.
Maybe the cf is the opposite of what we need...
According to Leonhard's explanation:
maybe we should calculate something like:
samples * sqrt(sum(samples^2)/No_Samples)
This would account for the actual (high-pass filtered) level of vibration and its variation.
I guess we need some mixture.Maybe the coefficient of variation to make it comparable between different setups.
But somehow it seems we need to analyze more logs...
Yes, definitely need too look at more data. This is largely why I posted this, to get the discussion going. Maybe needs it's own thread or something.
If it's of any use; my quad has pretty low vibes...circa 0.5-1 and I'm still on RC5...I can flash RC7 tomorrow morning and do a quick loiter and upload both an RC5 and RC7 log?
Yes! Both: important and interesting.
Maybe the difference comes from different logging rates. I was flying rc6.
294
295
296
297
298
of 449 Next
