Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
                    Richard,
                    You're right in AC3.2.1 there's no COMPASS_USE2 parameter so there's no way to disable just the compass consistency pre-arm check.  So the only way around it would be to set the ARMING_CHECK to Skip-Compass which disables this check plus all other compass related checks.  My guess is that with AC3.2 just waving the copter around a bit will also let it get past the compass consistency check because it's not that strict... it's meant to catch really large compass orientation errors.
                    ... this is just a pre-arm check .. not sure this is really worthy of an AC3.2.2 release at least not on it's own.
                  • re- Both AC3.2.1 and AC3.3 will actually never fail-over to the backup compass so it's really just a matter of ignoring the internal compass during the pre-arm checks if it's been set to COMPASS_USE2 = 0
                    I'm flying 3.2.1 and don't see COMPASS_USE2 ??
                    I see COMPASS_PRIMARY
                    then COMPASS_USE
                    but no COMPASS_USE2
                    The fix should be added to 3.2?? Our point???
                    also note related here http://ardupilot.com/forum/viewtopic.php?f=100&t=12522&sid=...
                    re- boat take off THANK_YOU_X100
          • https://youtu.be/1TQQcBWV6Vs
            • Hey Rainer,
              After watching the video you posted, I came a cross the below one.
              Many people saying it is fake. I don't know why would someone go through all hassles to make a fake video. These things happening even with super expensive systems because those expensive systems aren't the best. They are just expensive!..
              https://www.youtube.com/watch?v=87qI0QcbPBw
      • Developers, please, please ignore this ridiculous request.  The rapid and bold development made over such short timescales is nothing short of amazing and the stability is incredible given the complexity involved and potential for regressions and bugs.
        There is a perfectly good stable branch/release for those that want to use stable code, used by thousands out there with excellent results.
          Thank you!
        • So ridiculous it's been done many times apparently. lol
          It is nice that this forum is ussually polite and courteous to all views.  Much more so than most. I think we should all try and keep it that way.
          • @Richard,
            Did you get your Taranis Mavlink sorted out? I sent another reply but it was buried in the thread. I have my Serial2 protocol set to 2 instead of 3 which makes no sense as 2 is not even listed in the wiki listing. Can't explain it but it works on all of my aircraft. Let me know how you come out on this, sounds like we are in a similar place.
            Cheers,
            RB
            • I tried that and it did start to give me data but then it keeps giving me strange audibles that make no sense. I'm using a script from droneshop must be a glitch with that. But thanks for the tip!  That is odd it works for you but so long as it does who cares :] I ended up going back to 3.2 for now and for some reason I no longer have the DCM bad heading problem!! Who knows why but I'll take it!
        • Thank you:)
Monday
Azjeg liked Azjeg's profile
Apr 27
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
