Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Trying to use photoscan, so hopefully there's a fix in MPs geo-ref tool soon!
            I tried to manually pull the CAM lines from the rc7 log into their own file and format them the same as a 3.2 log, so that the tool would accept them, but didn't have any luck. There ended up being 300 CAM lines for the 170 images that were taken, so I'm not even sure what's going on there...
            • Thanks for the info. I ended up just using the .tlog off the tablet to tag the images with a time offset. Took a bit of trial and error to get the offset close to where it should have been, but was still not as accurate as using the CAM messages.
            • Glenn, assuming 3 things: that the GPX file and the JPEGs are in the same folder, that you are located in that folder with the command line tool (whether Mac or PC), and that the time in the images and the time in the log are in sync, then the ExifTool command is "exiftool -geotag NameOfFile.gpx *.JPG" (match the case of the extension of your images). You'll get a bunch of error messages, but they have no consequences (anyway, they did not for me). Sample check the exif info by looking into one of the images: you should see the five newly added GPS tags. If you need to deal with a timezone or other time difference between images and GPX, you'll need to use the Geosync tag in the exiftool command: find out more about that here: http://www.sno.phy.queensu.ca/~phil/exiftool/geotag.html. I hope this helps. Let me know. Fred
            • Yes please Fred, do you mind posting the exiftool command you used? Also if there are any other steps to get the tags into the images that info would be appreciated!
              I have created the KMZ + GPX from the log, and have exiftool.exe and the gpx in the folder of the images to geotag.
            • I was facing the same problem as you, Glenn. My workaround was to export the log's GPS info into a GPX file using MP, then use ExifTool to to add the GPS tags to the JPEGs from the GPX file. I then used Agribotix to make the mosaic, which worked perfectly. Let me know if you need details.
              Fred
          • Are you using Pix4d?  If you are, their software will geotag for you, but with a little glitch.  The initial geolocation will all be in portrait mode instead of landscape if that's what you're shooting.  It will still process and they're looking into a fix right now but it'll get the job done.
  • This reply was deleted.
        LifeSTyle,
        If you have Tower connected it should tell you but also when arming, try arming in Loiter,  It won't let you arm unless it has a good lock and position estimate.
      LifeSTyle,
      Thanks for the report.
      Ok, so what happened here is takeoff happened before the EKF was confident in it's position (i.e. before home was set).  The EKF actually never became confident enough of it's position so the home was never set and the autonomous modes were never enabled.
      Generally we don't recommend taking off without a GPS lock if you hope to use GPS flight modes.  Bad things happen like the RTL location (aka home) is set wherever the vehicle happens to be when the EKF does finally decide it's position is ok.
      Anyway, it should be possible for the EKF to become happy while it's flying but it's not something we've tested too much on the dev team so we can look into that further.
  • Hi.
    I tried to use RC8 on the same copter that crash with RC7. After a few minutes of flight received a message in MP - Error compass variance, after that copter tilted approximately for 30 degrees and started to fly in opposite direction. Fortunately I landed it without crash.
    In logs vibrations are normal as I can see.
    2015-07-27 18-37-04.bin
    • As I can see I have acceptable level of vibration for IMU and not acceptable for IMU2. I think is it a root of problem. Is AC3.3 more use IMU2 data that AC3.2?
