Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks Leonard... so we''ll expect it implemented tomorrow... LOL ... I understand fully on the time thing.
Great!!!!!! Thx!!
Hold your horses there.
From Chris' reply it seems "boat mode" will come to the SOLO, and since that is a different branch than the 3.3 "stock", we might not see this mode unless Randy or another dev ports it from upstream.
I believe Randy said he was fairly certain it would be in the next major update.
Yes, the "take-off from a boat" ability will be in AC3.4 and hopefully Solo will be brought back to master by then. In either case, it'll be in AC3.4. I hadn't thought about the 2nd issue Chris brought up - the case of taking-off in Loiter while the boat is moving and having the vehicle immediately lean back to try and stop itself.
re second issue
I don't know about anybody else but I never take off in any gps assisted mode. Too risky being in such close proximity to myself and my boat.. Alt hold or stab for me.
Yep. I typically only use Loiter once the aircraft is up and away from all obstacles.
Beautiful shot BTW. Did you use an filters? I'm looking to try a few, I wonder if a graduated ND filter will help with shots like that.
No filter on that shot. My brother had a ND filter and really liked it until it fell off in flight and lost it! He used it all the time. It helped with the sun through the prop issue too.
Awesome image.
