Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Manuel,
Marco's M8N parameters can now be found here in github.
Randy, just to let you know that using Marco's config file did the trick !!!
That or the change of GPS_TYPE to Ublox. I did those two at the same time, so I dont know for sure which made my quad fly well again
Thank you!
Thank you Randy
If I'm not able to 'save' my GPS unit by loading these parameters from another unit, what's the next step ?
I mean, I've only changed a few parameters within ublox ucenter software, how can that make a gps useless :|
@Pit. +1 here for M8N from CSG shop. I have 6 differents large M8N on different multirotors. They are really good here in east cost of Australia.
And the "new" improved ground plane incorporated (see photo) looks like a good way to isolate a it the electrical noise from "below".
All my M8N are mounted much higher than the main "platform" where electrical noise is common. I do add a sandwitch aluminium/copper plate under the GPS. The M8N are located about 15 to 18 centimeters away (above) from main noise sources. They *all* are powered with *clean power (read: Not switching one) This is much better than ferrite filter. Never had a GPS glitch so far in any of the six aircraft. Could it be purely coincidental? :-)
hee henri, no i think its not a coincidental. look, its my copter with the large CSG GPS. Works fine and i have 3 UBEC for powering the PIX. I think a clean construction its importend. U are right!
Today i will make a test with RC9
What's the diameter of that round one ?
About 10 centimetres (3.937007874015748031496062992126 inches) :-)
Yestarday, HDOP 0.7 (VR M8N)...
Hi Greg,
Really sorry about the crash....
I 'm not very good with logs... only the "basics", but I can’t see anything related with GPS, again ....I’m not a specialist.
By the way... I really recommend for everybody... a good anti-vibration system, I’m using the regular one with small blue shock absorbers , and gel pads to fix the board …. After this implementation “I feel” a hundred times better…..
I’m using this “double cushion” in my olds APMs, Pixhawks and Navio+ boards…..with very good results.
I had a GPS glitch today on rc8, but the EKF GPS glitch filter didn't catch it. I was hovering in the back yard with an M8N with 15 sats, and a fix type of 4, and descended to just below roof height while in Poshold, when the gps dipped to 12 sats, and the copter made a fast correction towards the house before I switched quickly to stab. Fix type changed to 3 soon after this and stayed that way till landing.
I've read the description on http://copter.ardupilot.com/wiki/gps-and-gcs-failsafes/gps-failsafe/ but still can't quite visualise how it would accept the glitched GPS position as valid, while not really having any lateral movement to project a trajectory. The new position it was trying to get to must have been a few metres away.
Is there a strategy for tuning the EKF glitch parameters to make it more resilient to glitches like this? I'd like to make sure these things don't make any unexpected movements when coming into land.
Here's a log.
208
209
210
211
212
of 449 Next
