Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
All things to be better are going to be welcome but Pos Hold and simple mode is after and before for me; great work :D :D ....I'm the president of Pos Hold fans club ;)
Hi Kurt,
I am not a big fan of Pos Hold but every mode has a place and this one was a very popular addition.
Thank's for clarification
That's Loiter better than Pos hld to land in that conditions?
There are actually parameters that can be used to adjust the slow-down speed. I haven't played with them yet but they come from the Solo people.
WPNAV_LOIT_MAXA = 1000
WPNAV_LOIT_MINA = 90
WPNAV_LOIT_JERK = 940
WPNAV_LOIT_SPEED=900
Hi stubugs,
Loiter doesn't break like pos hold. Loiter is designed to drift to a stop like stabilize does. The intent of loiter is it should resemble stabilize on a calm day no matter how windy it is.
So when you let the sticks go it slowly drifts to a stop. If you want it to stop quicker you need to reverse the sticks in the same way you would in stabilize.
Hope this makes it clear.
I think the same when this lovely mode appears but I read from devs that Loiter is usefull for videos, you can fly a constant low velocity, that's true (or what I understand in my bad english)
Hi Cala and others,
Personally I think Loiter gives a lot more control compared to Pos Hold and I personally don't use Pos Hold for that reason. I use Stab, Alt Hold, then Loiter and find Pos Hold just an ugly switching mode between Alt Hold and Loiter.
I intend to do some work on Loiter for the next release that will make it even smoother and more responsive to stick input. I also intend to do some work on Pos Hold so that it does a better job of adjusting for wind when you are flying it around. I suspect after those changes both modes will be hard to fault. In the end Loiter will always provide the pilot with greater control, at slow speeds, than pos hold because it doesn't break when the sticks are near centre.
Major problem with loiter right now is this - when GPS gets switched or gets wrong coordinates - craft darts to a side and in loiter reaction to input controls is sometimes not sufficient to counteract in time, so it you fly close to a building, like for a roof inspection - you can crash.
PosHold reacts way faster. But core problem is still how craft reacts to GPS coordinates glitches, it really has to be fixed somehow.
The problem is that the GPS signal coming from one of the Satellites is bounced off the roof causing it to be delayed getting to the GPS. This causing the position to move towards the house and the copter compensates by flying away rapidly.
This can be seen by flying in Stabilize mode or Alt Hold near a building and watch a trace of the GPS from the logs.
As far as the GPS is concerned it is getting a valid signal just not a good one. About the only thing that could be done is if the position moves very rapidly in one direction suddenly to ignore it as a bad position but how do you now how long to wait before accepting it again and what do you do in the mean time.
I have seen where the GPS position will jump as much as 100 meters in one direction. This happens as the copter is moving up or down near the roof line which causes the signal to suddenly bounce and disappear.
GPS was never designed to work in or around structures.
Thank's Leonard to clarificate, I fly a lot in FPV and I prefer this modes because no risk to drift to sides like Althold, in other way, at the begining, Poshold save my copter from a Fly Away, I made a mistake configuring Failsafe (TX and Dragon to configure) and copter stays in place waiting that I move and recover signal (FIUUU!!!!).
107
108
109
110
111
of 449 Next
